Momentum, Impulse and collisions Q
In summary: This is because momentum is kgm/s and v1 and v2 are velocities in m/s, so you have (kgm/s)-(kgm/s)=kgm/s. 2. ∴v=P/m ∴ 4,000 / (1200+2200) = 1.17 m/s The velocity after the collision is correct.3. Q2Since F=m*a ∴ F=2200*awhere a = (v-u)/t ∴ (1.176-10)/0.4 = -22.06 m/s^2 The acceleration is correct, but the force is not. The force is equal to -48,529.4 Newtons, not -22.
leechyeah
A car of mass 1200kg traveling at a velocity of 15m/s North collides head on with a small van of mass 2200kg traveling at 10m/s South. The vehicles stick together on impact and the collisions can be considered an isolated one. The contact time of the collision is 0.4 seconds.
  1. Calc the velocity of thethe vehicles after the collision.
  2. Calc the average force of the van on the car.
  3. State average force of the car on the van.
  • F=m*a
  • F=(mass*Δvelocity)/Δtime
  • momentum=mass*velocity
  • ΔP=Pfinal-Pinital (note: p is momentum)
  • Total P= m1v1 + m2v2
The following calculations are correct now.
  1. Total P= m1v1 + -(m2v2) car in opposite direction
    ∴(2200*10)-(1200*15)=4,000 Ns(Newton secundum)
    Since P=mv ∴v=P/m ∴ 4,000 / (1200+2200) = 1.17 m/s
  2. Q2
    thus F=2200*-22.06 = -48,529.4 Newtons
  3. Same as q2, 48529.4 Newtons but in opposite direction, hence the +/- sign.
    Proof:
    F=1200*a
    where a = (v-u)/t ∴ (1.176-(-15))/0.4 = 40.4412 m/s^2
    thus F=1200*40.4412 = 48529.4 Newtons
I am not really sure I understand your attempt.
Q1 refers to a velocity as an answer and you have a force.
Have you got an answer for this question?
Hi CAF123,
Thanks for your help, I've updated my calculations now. I'm not sure about if it's right though. Please help me check.
Hi leechyeah, welcome to PF.:smile:
Q2 asks the force the van exerts on the car. How long does that force act?
You have written that the change of the momentum of a body is equal to the force exerted on it multiplied by the time during the force acts. ΔP=FΔt.
The momentum of the car has changed. By how much?
ehild
Hi ehild,
I understand that there is something wrong, but I am confused as to what it is.
Shall I use t=0.4 secs, given in the question?
  1. Calc the velocity of the vehicles after the collision.
  • F=m*a
  1. ΔP=Pfinal-Pinital
    ∴(2200*10)+(1200*15)=40,000 Newtons
    Since P=mv ∴v=P/m ∴ 40,000 / (1200+2200) = 11.76 m/s
  2. Q2
    where a = (v-u)/t ∴ (11.76-10)/0.4 = 4.41 m/s^2
    thus F=2200*4.41 = 9705.88 Newtons
  3. Same as q2, 9705.88 Newtons
    Proof:
    F=1200*a
    where a = (v-u)/t ∴ (11.76-15)/0.4 = -8.088 m/s^2
    thus F=2200*-8.088 = -9705.88 Newtons
The total momentum of the cars is conserved during collision. The total momentum is P=m1v1+m2v2 but the velocity v and the momentum P are vector quantities. The car and the van traveled in opposite directions, one of the velocities positive, the other is negative. Take that into account.
(By the way, the unit of momentum is Ns or kgm/s, not Newton)
ehild
leechyeah said:
Hi ehild,
Yes, that you used correctly. The total momentum was wrong.
ehild
Use conservation of momentum to find the combined velocity of the vehicles:
[itex] m_1v_1 + m_2v_2 = (m_1 +m_2)V, [/itex] where [itex] V [/itex] is the velocity you are looking for. Note in your attempt, you forgot that velocity was a vector.
Thanks for the clarification. Does "Ns" actually stand for anything?
I updated my original post. However, Q3 is where I'm unsure of.
Ns is Newton-secundum.
As for Q3 think of Newton's third law. If the van exerts F force on the car, how big is the force the car exerts on the van?
Of course, you can also calculate the change of momentum of the van, and divide it by 0.4 s.
ehild
The combined velocity is now correct.
The reason you are getting different forces now is due to your signs. You know they should be equal because of Newton's 3rd. Retry this but using the right signs.
'Ns' is a Newton second.
Thanks,
I understand the net force for q2 and q3 must be the same, however my calculations do not match. Which part is wrong?
in q1, If I use 11.76 instead of 1.176, then everything else will work out...
Ok, so [itex] F = \frac{m(V-v_1)}{t}. [/itex] [itex] V [/itex] here is always ≈ -1.2m/s. You just need to make sure the signs are right for [itex] v_1 [/itex] and [itex] v_2 [/itex]
Thanks got it, -15 m/s.
I will amend the original post.
PS: How come you guys didn't work it out step-by-step for me? ;o
If you mean provide a step by step solution, then all I can say is that we are not allowed to do that. Besides, it is a lot more satisfying solving a problem yourself and it is better for you.
Its the beauty of PF and specially Mr Ehild ,
They will push you enough so that you come out with answer yourself , and this is exactly the right way of teaching physics . .
I see,
Thank you all for your help. Lastly, do each of you agree my with my final solution?
I don't have the textbook solutions at the moment.
yup calculation seems alright
1.Total P= m1v1 + -(m2v2) car in opposite direction
∴(2200*10)-(1200*15)=4,000 Newtons
Your solution is correct. Just to point out that in the above line of working, the units should be kgm/s, not Newtons.
FAQ: Momentum, Impulse and collisions Q
What is momentum?
Momentum is a measure of an object's motion, calculated as the product of its mass and velocity. In other words, it is the amount of force an object has when in motion.
How is momentum different from velocity?
While velocity is a vector quantity that describes the speed and direction of an object, momentum is a vector quantity that represents the quantity of motion an object has. Velocity only describes the speed and direction of an object, while momentum takes into account its mass as well.
What is impulse?
Impulse is a change in momentum that occurs when a force is applied to an object over a period of time. It is calculated as the force applied multiplied by the time over which it acts.
How are momentum and impulse related?
Momentum and impulse are closely related, as impulse is the change in momentum that occurs when a force is applied to an object. In other words, the greater the impulse, the greater the change in momentum.
How does the law of conservation of momentum apply to collisions?
The law of conservation of momentum states that in a closed system, the total momentum before a collision is equal to the total momentum after the collision. This means that the total momentum of all objects involved in a collision will remain constant, regardless of any individual changes in momentum.
