Momentum/Impulse [Final Velocity]
In summary, a truck weighing four times as much as a car collides with the car at 12 km/h and they stick together. The final velocity of the combined objects can be determined by using the equation for conservation of momentum, where the initial momentum of the truck is equal to the final momentum of the combined objects.
silverduelist
"A truck weighs four times as much as a car, If the truck coasts into the car at 12 km/h and they stick together, what is their final velocity."
Change in momentum a = change in momentum b
OR
m1v1 = m2v2
OR
(delta)P system = 0
I HAVE NO IDEA. SRSLY.
OR
m1v1 = m2v2
OR
(delta)P system = 0
Welcome to Physics forums.
As you have correctly surmised, momentum is conserved in this case (since there are no net external forces acting). All three of your relevant equations are equivalent, so how about trying to apply one of them to this problem?
I understand that momentum and impulse are important concepts in physics that describe the motion of objects. In this situation, we can use the equation Change in momentum a = change in momentum b or m1v1 = m2v2 to solve for the final velocity of the truck and car after they collide.
Since the truck weighs four times as much as the car, we can assign the truck's mass as 4m and the car's mass as m. We also know that the truck's initial velocity is 12 km/h and the car's initial velocity is 0 km/h since it is at rest.
Using the equation, we can set up the following equation:
(4m)(12 km/h) = (m + 4m)v2
Simplifying the equation, we get:
48m km/h = 5m v2
Dividing both sides by 5m, we get:
9.6 km/h = v2
Therefore, the final velocity of the combined truck and car is 9.6 km/h. This means that the two objects will continue to move together at a speed of 9.6 km/h after the collision.
In conclusion, by using the principle of conservation of momentum, we can determine the final velocity of the truck and car after they collide and stick together. This is just one application of momentum and impulse in the real world, and it is important to understand these concepts in order to accurately describe and predict the motion of objects.
FAQ: Momentum/Impulse [Final Velocity]
What is momentum?
Momentum is a physics concept that describes the quantity of motion an object has. It is calculated by multiplying an object's mass by its velocity.
What is impulse?
Impulse is a change in momentum. It is calculated by multiplying the force acting on an object by the time it acts for.
What is the relationship between momentum and final velocity?
The final velocity of an object is directly proportional to its momentum. This means that as an object's momentum increases, so does its final velocity.
How is momentum conserved in a closed system?
In a closed system, the total momentum before and after a collision remains the same. This is known as the law of conservation of momentum.
How can momentum and impulse be used in real-life applications?
Momentum and impulse are important concepts in understanding the motion of objects, such as in sports and car accidents. They are also used in engineering and designing machines, such as in airbags for cars.
