Momentum: Jumping on a trampoline
In summary: Remember, momentum is a vector quantity, so direction always matters. And when calculating change in momentum, you need to consider both the magnitude and direction of the initial and final momenta.
smagro
A gymnast of mass 40kg is practising on a trampoline.
The gymnast lands with a speed of 6.3m/s. The gymnast rebounds with a speed of 5.7m/s.
a) Calculate the change in momentum of the gymnast
b) The gymnast was in contact with the trampoline for 0.50s. Calculate the average force exerted by the trampoline on the gymnast.
Momentum = mass x velocity
Force = change in momentum/time
a) momentum before = 40kg x 6.3m/s = 252kgm/s
momentum after = 40kg x (-5.7m/s) = -228kgm/s
change I am momentum = final momentum - initial momentum
= -228kgm/s - 252kgm/s = -480kgm/s
b) Force = -480 / 0.50s = -960N.
Is this correct?
Looks good to me! (You have used the convention that down = positive, which is perfectly OK.)
some arguments against my working were that the gymnast change in momentum was from 0m/s to 5.7m/s because the gymnast was at rest at the maximum stretching point of the trampoline.
this will make the change in momentum be 228kgm/s - 0 kgm/s = 228kgm/s.
then the force is 228/0.50 = 456N
what is your opinion?
is it also good to argue that the upward force by the trampoline should be greater than the weight of gymnast?
I would say that that is wrong. Note that if you only count from the lowest point (where the gymnast is momentarily at rest) the time of contact time would be less than 0.50 seconds.
This is not a matter of opinion. These arguments are incorrect.
Chet
It had better be! Otherwise, how can the gymnast be accelerated upwards?
Also, what you've calculated is the net upward force on the gymnast. You need to factor out gravity to get the force of the trampoline. (Sorry for not pointing that out!)
So you'll need to correct your initial analysis.
what if the collision was an elastic collision. momentum before should be equal to the momentum after.
so the gymnast should rebound with a speed of 6m/s.
but if we work momentum, momentum (being a vector quantity), we get 40kg x 6.3m/s = 252kg/ms
momentum after = 40kg x -6.3m/s = -252kgm/s.
So momentum is not conserved!
Why would you think momentum is conserved? There's an external force acting on the gymnast--the trampoline!
(Don't confuse this with the usual problem of two objects colliding, such as two balls. There, the total momentum of both objects is conserved.)
thanks...
summary: momentum is a vector quantity and direction has to be considered in working out the change in momentum.
There is no argument about that.
Most definitely!
FAQ: Momentum: Jumping on a trampoline
What is momentum and how does it relate to jumping on a trampoline?
Momentum is a measure of an object's mass and velocity. When jumping on a trampoline, momentum is created when you push off the trampoline surface, and it allows you to continue jumping up and down.
Does the size or weight of a person affect their momentum on a trampoline?
Yes, the size and weight of a person can affect their momentum on a trampoline. A heavier person will have a greater mass, which means they will need more force to create the same amount of momentum as a lighter person. However, the size of a person does not have a significant impact on their momentum.
How is momentum conserved while jumping on a trampoline?
Momentum is conserved on a trampoline because the force created by the person jumping is equal to the force of the trampoline pushing back. This allows the person to continue jumping up and down without losing momentum.
Can the material or tension of the trampoline affect momentum?
Yes, the material and tension of the trampoline can affect momentum. A trampoline with a tighter surface or springs will provide more resistance and allow for greater momentum, while a looser surface or weak springs may decrease momentum.
How does the angle of the jump affect momentum on a trampoline?
The angle of the jump can affect momentum on a trampoline. A more vertical jump will create more force and momentum, while a flatter jump will create less force and momentum. This is because a more vertical jump allows for a greater push off the trampoline surface.
