Momentum of cannon ball homework
In summary, a cannon shoots a shell straight up and it reaches a maximum height of 875 feet. The shell then splits into two pieces, 3 lb and 5 lb, which are observed to strike the ground simultaneously. The 5 lb piece hits the ground 1,659 feet away from the explosion. To find the magnitude of the velocity of the 5 lb piece just after the explosion, conservation of energy is not required. Instead, the problem can be solved by considering the horizontal and vertical components of the motion. Both components have two equations with two unknowns, making it solvable through projectile motion. However, it can also be solved through momentum as the fragments behave like a two-dimensional collision.
Aggie
A cannon shoots a shell straight up. It reaches its maximum height, 875 feet, and splits into two pieces, one weighing 3 lb and the other 5 lb. The two pieces are observed to strike the ground simultaneously. The 5 lb piece hits the ground 1,659 feet away from the explosion (measured along the x axis). Find the magnitude of the velocity of the 5 lb piece just after the explosion.
Work done before explosion = 8lb * 32 ft/s^2 * 875 ft = 224000 J
work done before explosion = work done after explosion
work done after explosion = work done by 3lb + work done by 5 lb = 224000 J
work done by 3lb= 3lb * 32 ft/s^2 * 875 ft = 84000 J
work done by 5 lb = 224000 - 84000 = 140000 J
work = integral of force done
work done by 5 lb = integral of force in x direction + integral of force done in y direction
where do I go from here?
Convervation of energy is not required for this question. Have you met any kinematic equations before?
yes i have
So, let's consider this problem in horizontal and vertical components. List the knowns and unknowns in each direction.
xcomp of 3 lb
a = 0
v= Vo
s=Vot + So = 0
Y comp of 3 lb
a= g
v= gt + Vo
s= gt^2/2 + Vot + So
xcomp of 5 lb
a = 0
v= Vo
s=Vot + So = 0= Vot + 1659
Y comp of 5 lb
a= g
v= gt + Vo
s= gt^2/2 + Vot + So = 0 =gt^2/2 + Vot + 875
Looks good to me :biggrin:, there's no need to consider the path of the 3lb particle since we are not asked to calculate it in the question. One small correction for your 5lb y component;
s= -gt^2/2 + Vot + So = 0 =-gt^2/2 + Vot + 875
So now you have two equations with two unknowns, I'm sure you know how to proceed from here.
Actually as said this is a momentum problem; so need to do all that ugly stuff =p. You're already past the "grunge" way of doing the problems.
It's like the idea of a ball striking another ball and both going off at different angles. This is a two dimensional collision essentially.
One piece will go off at angle gamma, the other will go off at angle beta.
I disagree, the problem is solvable if we consider it as a purely projectile motion problem, the fragment will behave as if it was a projectile given some initial horizontal velocity at some height above the ground [ignoring air resistance of course].
You can do it that way; however, it is a grunt method. The key thing was that it is momentum, so he/she should be learning it through momentum.
Such as you could go about projectile motion in how far something will land. Set it up into the x and y vectors, say that there's no acceleration in the x and do a lot. However, you can accomplish it through energy.
Momentum is the key in this and how to apply it is like with 2 dimensional collision. Same idea applies.
Related to Momentum of cannon ball homework
What is momentum?
Momentum is a measure of an object's motion and is calculated by multiplying its mass by its velocity.
How is momentum related to a cannon ball?
The momentum of a cannon ball is directly related to its mass and velocity. The larger the mass and/or the faster the velocity, the greater the momentum of the cannon ball.
What is the equation for calculating momentum?
The equation for calculating momentum is p = mv, where p represents momentum, m represents mass, and v represents velocity.
How does the momentum of a cannon ball change during flight?
The momentum of a cannon ball remains constant during flight, assuming there are no external forces acting on it. This is known as the law of conservation of momentum.
How is momentum useful in understanding the motion of a cannon ball?
Momentum is useful in understanding the motion of a cannon ball because it helps us predict how the cannon ball will behave and interact with other objects in its path. It also allows us to calculate the force required to stop or change the direction of the cannon ball.
