MHB Momentum of Falling Ball X & Ball Y: A Physics Puzzle
Ball X, with a mass of 0.03 kg, falls from a height of 30 m, while Ball Y, with a mass of 0.01 kg, is projected upwards at 20 m/s. To find the downward momentum of each ball just before they meet, the equations of motion for both balls are used, leading to the determination of their velocities at the point of collision. After they coalesce, the combined object’s velocity is calculated using conservation of momentum. The time taken for the combined object to reach the ground is shown to be 2.68 seconds after Ball X started to fall. This problem illustrates the principles of momentum and kinematics in a dynamic system.
Shah 72
MHB
Ball X has mass 0.03kg. It falls vertically from rest from a window that is 30 m above the ground. Ball Y has mass 0.01kg. At the same time that Ball X starts to fall, Ball Y is projected vertically upwards from ground level directly towards Ball X. The initial speed of Ball Y is 20 m/s vertically upwards.
a) Find the downward momentum of each Ball just before they meet.
The Ball coalesce and the combined object falls to the ground.
b) show that the combined object reaches the ground 2.68 s after Ball X started to fall.
Pls help as I don't know how to solve.
Mathematics news on Phys.org
let $d$ be the distance above ground the two masses collide ...
$d = 20t - 5t^2$
$-(30-d) = -5t^2$
solve for $t$, the time of collision, and $d$
falling mass, $v_{f1} = 0 - 10t$
rising mass, $v_{f2} = 20 - 10t$
conservation of momentum ...
$Mv_{f1} + mv_{f2} = (M+m)V$, where $V$ is the velocity of the combined masses after the collision
you should have the position of collision and $V$ the initial velocity after the collision ... calculate the time necessary to hit the ground and add to the time of collision
$d = 20t - 5t^2$
$-(30-d) = -5t^2$
Thank you very much!
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
