Momentum operator eigenfunction
In summary, the conversation discusses the concept of momentum operator and its eigenfunctions in different notations and representations. It also touches on the use of Dirac notation and the importance of distinguishing between different descriptions in quantum mechanics. The conversation ends with a request for book recommendations for studying graduate-level quantum mechanics.
blue_leaf77
2,637
786
This might be trivial for some people but this has been bothering lately.
If P is momentum operator and p its eigenvalue then the eigenfunction is up(x) = exp(ipx/h). where h is the reduced Planck constant (sorry can't find a way to make the proper notation).
While it can also be proved that <x|p> = exp(ipx/h) (omitting constant pre factor), where |p> is also momentum operator eigenfunction in different notation, in this sense one would say that up(x) = |p>. But why is <x|p> = up(x) instead?
I will appreciate anyone who is trying to enlighten me in this problem. Thanks in advance.
If P is momentum operator and p its eigenvalue then up(x) = exp(ipx/h). where h is the reduced Planck constant (sorry can't find a way to make the proper notation).
While it can also be proved that <x|p> = exp(ipx/h) (omitting constant pre factor), where |p> is also momentum operator eigenfunction, in this sense one would say that up(x) = |p>. But why is <x|p> = up(x) instead?
|p> is the momentum eigenfunction.
<x|p> is the representation of the momentum eigenfunction in the position basis.
I have also thought the same way, but then it suggests that P = h/i ∂/∂x is also representation of momentum operator in space coordinate, because it yields solution of eigenfunction up(x) = exp(ipx/h) = <x|p>. Does this means that there is other forms of P depending on which basis its eigenfunction is evaluated?
Yes, that's right.
Ah yeah I think that makes sense, when I want to evaluate <P> for wavefunction already represented momentum space, I don't need to replace P with h/i ∂/∂x, instead I shoud substitute P = p.
Ok thanks for your guide.
It is very important to distinguish the different descriptions. Dirac notation is the representation independent description of quantum theory in terms of an abstract (rigged) Hilbert space. The vectors ##|\psi \rangle## are abstract objects which come to life just from the definition of their properties through the axioms declaring what a Hilbert space is. The same holds for linear self-adjoint operators like ##\hat{p}## and ##\hat{x}##, which are defined in an abstract way by their commutator relations (Lie algebra of the translation group in 1 dimension, the socalled Heisenberg algebra,
$$[x,p]=\mathrm{i} \hbar \hat{1}.$$
It turns out from this algebra alone that both ##\hat{x}## and ##\hat{p}## have entire ##\mathbb{R}## as their spectrum, i.e., only continuous "generalized eigenvalues".
Now you can work in a specific representation by choosing an arbitrary complete set of (generalized) eigenvectors of an observable like the position. It's not a true Hilbert-space vector but a distribution, living in the dual space of the dense subspace of the Hilbert space, where the position and momentum operators are defined. It's "normalized to a ##\delta## distribution":
$$\langle x'|x \rangle=\delta(x-x').$$
The true normalizable Hilbertspace vectors are mapped to square-Lebesgue-integrable functions (vulgo "the wave function"),
$$\psi(x)=\langle x|\psi \rangle.$$
The Heisenberg algebra in position representation is given by
$$\tilde{x} \psi(x):=\langle x|\hat{x} \psi \rangle=\langle \hat{x} x|\psi \rangle=x \langle x|\psi=x \psi(x)$$
and
$$\tilde{p} \psi(x)=-\mathrm{i} \hbar \partial_x \psi(x).$$
Now you can look for the generalized momentum eigenfunctions in position representation, leading to
$$\tilde{p} u_p(x)=p u_p(x) \; \Rightarrow \; u_p(x)=N_p \exp(\mathrm{i} p x/\hbar).$$
Again, that's a distribution, normalizable to a ##\delta## distribution. Using the completeness relation for the generalized position eigenstates,
$$\int_{\mathbb{R}} \mathrm{d} x |x \rangle \langle x|=\hat{1},$$
you get
$$\langle p|p' \rangle=\int_{\mathbb{R}} \mathrm{d} x \langle p| x\rangle \langle x|p' \rangle=\int_{\mathbb{R}} \mathrm{d} x u_p^*(x) u_{p'}(x) = \int_{\mathbb{R}} \mathrm{d} x N_{p}^* N_{p'} \exp[\mathrm{i} x(p'-p)/\hbar]=|N_p|^2 2 \pi \hbar \delta(p-p'),$$
as is well-known from the maths of the Fourier transformation. Thus up to an irrelevant phase factor we have found the properly normalized generalized momentum eigenvector in position representation to be
$$u_p(x)=\frac{1}{\sqrt{2 \pi \hbar}} \exp(\mathrm{i} p x/\hbar).$$
Now you can also work in momentum representation. The corresponding wave function is
$$\tilde{\psi}(p)=\langle p|\psi \rangle=\int_{\mathbb{R}} \mathrm{d} x \langle p | x \rangle \langle x | \psi \rangle=\int_{\mathbb{R}} \mathrm{d} x u_{p}^*(x) \psi(x)= \int_{\mathbb{R}} \mathrm{d} x \frac{1}{\sqrt{2 \pi \hbar}} \exp(-i p x/\hbar) \psi(x).$$
In the same way you find the inverse relation,
$$\psi(x)=\langle x|\psi \rangle=\int_{\mathbb{R}} \mathrm{d} p \langle x|p \rangle \langle p|\psi \rangle=\int_{\mathbb{R}} \mathrm{d} p u_p(x) \tilde{\psi}(p)= \int_{\mathbb{R}} \mathrm{d} p \frac{1}{\sqrt{2 \pi \hbar}} \exp(\mathrm{i} p x/\hbar) \tilde{\psi}(p),$$
as also expected from the maths of Fourier transformations.
Thanks vanhees71, your post has deepened m understanding.
I have gotten part of those stuffs in my undergrad except for Hilbert space thing. And looks like I need to self-study the next level of quantum mechanics since I don't get quantum mech for graduate in my current program but I will have to be dealing with it again for my master thesis. So, any suggestion for not-so-hard-to-understand books on graduate quantum mechanics?
Sakurai, Modern Quantum Mechanics
Ballentine, Quantum Mechanics
Weinberg, Lectures on Quantum Mechanics
Related to Momentum operator eigenfunction
1. What is the momentum operator eigenfunction?
The momentum operator eigenfunction is a mathematical function that describes the spatial distribution of a particle's momentum in quantum mechanics. It is a solution to the Schrödinger equation and is used to calculate the probability of finding a particle with a particular momentum value.
2. How is the momentum operator eigenfunction related to the uncertainty principle?
The momentum operator eigenfunction is directly related to the uncertainty principle in quantum mechanics. The uncertainty principle states that the more precisely we know a particle's position, the less precisely we can know its momentum, and vice versa. The momentum operator eigenfunction helps us understand the relationship between a particle's position and momentum in quantum mechanics.
3. What are the key properties of the momentum operator eigenfunction?
The momentum operator eigenfunction has a number of important properties, including being a complex-valued function, being an eigenfunction of the momentum operator, and being normalized to a unit integral. It is also a continuous function and describes the probability density of finding a particle with a specific momentum value.
4. How is the momentum operator eigenfunction used in practical applications?
The momentum operator eigenfunction is used in a variety of practical applications in quantum mechanics, such as calculating the energy levels and wave functions of particles in a potential well, predicting the scattering behavior of particles, and understanding the dynamics of quantum systems. It is also used in the development of advanced technologies, such as quantum computing and quantum cryptography.
5. What are some common misconceptions about the momentum operator eigenfunction?
One common misconception about the momentum operator eigenfunction is that it represents the actual physical momentum of a particle. In reality, it is a mathematical function that describes the probability of measuring a certain momentum value. Additionally, some people may incorrectly assume that the momentum operator eigenfunction is the same as the momentum operator itself, when in fact they are distinct mathematical entities with different properties and uses.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
