Momentum operator of the quantized real Klein-Gordon field
In summary, the conversation discusses the creation and annihilation of particles with wave number vector k and the definition of Klein-Gordon field operators. The momentum operator and commutation relation are also mentioned. The individual's attempt at solving the problem is explained and a request for assistance is made.
Baluchiterium
a+(k) creates particle with wave number vector k, a(k) annihilates the same; then the Klein-Gordon field operators are defined as ψ+(x) = ∑_k f(k) a(k) e^-ikx and ψ-(x) = ∑_k f(k) a+(k) e^ikx; the factor f contains constants and the ω(k). x is a Lorentz four vector, k is a 3-vector except in the exponential where it is also a four vector.
The momentum operator is defined as P = ∫∫∫ d^3x 1/c^2 ∂/∂t ψ(x) ∇ψ(x) where ψ(x) = ψ+(x) + ψ-(x).
Commutation relation is [a(k),a+(k')] = δ_kk'
Upon straightforward calculation of the derivatives and insertion into the expression for the momentum operator I get the correct constant term for the infinite momentum, but not the number operator term for bosons. The result should be P = ∑_k hbar k ( a+(k) a(k) +1/2). I get the second but not the first term. The problem is that two terms appear in which I have a pair of creators and a pair of annihilators, respectively, but the mixed term vanishes after using the commutation relation. What am I missing? The problem is to be found on pages 40 and 41 of Mandl and Shaw, Quantum Field Theory. Thanks a lot for any kind of hint.
Could you post your exact calculation?
Related to Momentum operator of the quantized real Klein-Gordon field
1. What is the momentum operator of the quantized real Klein-Gordon field?
The momentum operator of the quantized real Klein-Gordon field is a mathematical operator that describes the momentum of a particle in the field. It is derived from the Klein-Gordon equation, which is a relativistic wave equation that describes the behavior of spinless particles.
2. How is the momentum operator related to the quantized real Klein-Gordon field?
The momentum operator is an essential part of the quantized real Klein-Gordon field theory. It is used to calculate the momentum of a particle in the field and to derive other important physical quantities, such as the energy and angular momentum.
3. What is the significance of the momentum operator in the quantized real Klein-Gordon field?
The momentum operator plays a crucial role in the quantized real Klein-Gordon field theory. It allows us to study and understand the behavior of particles in the field, including how they interact with each other and the surrounding environment.
4. How is the momentum operator used in practical applications?
The momentum operator is used in various practical applications, such as quantum field theory, particle physics, and cosmology. It helps us to make predictions and calculations about the behavior of particles and fields in these areas of study.
5. Are there any limitations or challenges associated with the momentum operator in the quantized real Klein-Gordon field?
Like any mathematical operator, the momentum operator has its limitations and challenges. One limitation is that it only applies to spinless particles, and it cannot describe the behavior of particles with spin. Additionally, there are challenges in applying the momentum operator to complex systems, such as those with multiple interacting particles in the field.
