Momentum operator -- Why do we use the plane wave solution?
In summary: Yes, I agree, but still, is there some deeper meaning behind plane waves? Is it "just" most physically appropriate?I think that it is quite nice tool when we can decompose any field into a set of harmonic oscillators. One of the reasons is that we can solve the harmonic oscillator problem in QM completely analytically. No perturbation theory or variations or any numerical method.Yes, I understand that but aren't the things you said just consequences? It is like it bothers me in some fundamental QM way. I mean I can't be satisfied with the argument that it gives nice solutions. I mean, it is obviously correct considering the experiments in QM.I
zb23
27
Why in order to derive the QM momentum operator we use the plane wave solution. Why later on in field theory and particle physics, the plane wave ansatz is so physically important?
Because we can write any field in qft as a superposition of plane waves.
That's the main basis for mathematical physics. Why represent force as a vector? Why is time a parameter in non-relativistic physics? Why have a spacetime manifold in relativity?
Likes mattt and simonjech
Of course, I understand, I mean I am currently doing field theory in particle physics and some arguments for plane wave solutions, for me, lack some structure, therefore I asked...I just wanted to get some more insight into some basics...
Can you give some specfic references to arguments that you find lacking?
You don't have to do it in that old-fashioned way.
A more modern approach is to examine the Lie algebra of Galilean transformations as an abstract group. Then, representing that algebra in coordinate representation, implies that the operator of spatial translation, (##P_i = -i \hbar \partial_i##), must satisfy ##P = MV## (for a free particle), which is the usual expression for momentum.
For a detailed exposition of this, see Ballentine chapters 3 and 4.
Likes zb23, Nugatory, vanhees71 and 2 others
FAQ: Momentum operator -- Why do we use the plane wave solution?
What is the momentum operator in quantum mechanics?
The momentum operator in quantum mechanics is an operator that corresponds to the classical concept of momentum. In the position representation, it is typically denoted as \( \hat{p} \) and is defined as \( \hat{p} = -i\hbar \frac{\partial}{\partial x} \), where \( \hbar \) is the reduced Planck constant and \( x \) is the position variable.
Why do we use the plane wave solution in quantum mechanics?
We use the plane wave solution in quantum mechanics because it is an eigenfunction of the momentum operator. Plane waves have the form \( \psi(x) = Ae^{ikx} \), where \( k \) is the wave number. When the momentum operator acts on a plane wave, it yields a simple eigenvalue equation \( \hat{p}\psi(x) = \hbar k \psi(x) \), making it easier to analyze and solve problems involving momentum.
How does the plane wave relate to the de Broglie hypothesis?
The plane wave solution is directly related to the de Broglie hypothesis, which posits that particles have wave-like properties. According to de Broglie, the wavelength \( \lambda \) of a particle is related to its momentum \( p \) by \( \lambda = \frac{h}{p} \), where \( h \) is Planck's constant. The plane wave \( \psi(x) = Ae^{ikx} \) embodies this wave-particle duality, with the wave number \( k \) related to the momentum by \( p = \hbar k \).
What is the significance of the plane wave being an eigenfunction of the momentum operator?
The significance of the plane wave being an eigenfunction of the momentum operator is that it allows for a straightforward interpretation of momentum in quantum mechanics. When a plane wave is used, the momentum operator acting on it yields a definite value (the eigenvalue), which corresponds to the momentum of the particle. This simplifies the analysis of quantum systems and helps in understanding the quantization of momentum.
Can the plane wave solution be used for all quantum mechanical problems?
No, the plane wave solution cannot be used for all quantum mechanical problems. It is ideal for free particles and situations where the potential is constant or negligible. However, for systems with varying potentials, such as particles in a potential well or in the presence of external forces, more complex wavefunctions that satisfy the Schrödinger equation under those specific conditions are required.
