Momentum paradox: Why can't we write it as p=m+v ?
In summary: What kind of unit would this hypothetical physical quantity have and what can it be used for? So we take 1 kilogram and 1 meter per second and add them and get 2 kg+m/s? What if we choose different units? Momentum will scale in the obvious manner, 1 kg·m/s = 1000 g·m/s, whether we multiplied 1kg by 1m or 0.5 kg by 2m/s, but your added quantity will depend on the values we adding up, so if we add 1kg and 1m/s it will be 2 kg+m/s = 1001 g+m/s, but if we add 0.5 kg and 1.5
akashpandey
90
So as we know momentum has a formula p=mv right ?
But why we can't write it as p=m+v ?
The real question is why we multiply both mass and velocity quantity
And not add them ?
  • Skeptical
Likes Delta2, sheepy_pasta, weirdoguy and 1 other person
Because observation tells us that ##mv## is a useful quantity, and ##m+v## makes no sense. You can't add quantities that have different dimensionalities.
Likes PhDeezNutz, KDPhysics, sheepy_pasta and 4 others
Ok so as we know multiplication is repeated addition..
How would explain momentum according to multiplication definition ?
Does this mean we are scaling velocity by multiplying mass.
Likes Delta2
Or more simply i can put the question like
What does multiplication mean? If we can't add two different types of quantities, then how can we multiply two different types of quantities, like p=mv ?
You can't add quantities with different units because it makes no sense. ##m+v## is the mathematical expression of a question like "what's 1kg more than 10m/s", which makes no sense at all.
You can multiply quantities with different units because the units also multiply. That's possible because quantities with units are already a multiplication - for example 3m is just saying "three times the length of a metre rule" in a compact way. And constructing compound units such as m/s is also clearly meaningful - it's the mathematical expression of a question like "how many times the length of a metre rule did an object travel in the time it took my clock to tick once".
(I'm aware that modern SI defines units in a slightly more sophisticated way than "here's a lump of metal of a defined length". It doesn't make a difference to the point at hand.)
Likes PhDeezNutz, Infrared, KDPhysics and 5 others
Yeah got your point..
But definition of multiplication doesn't go hand in hand with this momentum thing.. that's all i am saying.
m/s is how man times the length of a meter rule object traveled in one tick of my clock.
So how would mathematically define this "kg.m/s" ?
What kind of unit would this hypothetical physical quantity have and what can it be used for? So we take 1 kilogram and 1 meter per second and add them and get 2 kg+m/s? What if we choose different units? Momentum will scale in the obvious manner, 1 kg·m/s = 1000 g·m/s, whether we multiplied 1kg by 1m or 0.5 kg by 2m/s, but your added quantity will depend on the values we adding up, so if we add 1kg and 1m/s it will be 2 kg+m/s = 1001 g+m/s, but if we add 0.5 kg and 1.5 m/s we will get 2 kg+m/s = 501.5 g+m/s, which can't be derived independently from the original 2 kg+m/s without knowing the separate values that went into it. We'll have to keep track of this values all the time (kind of like that: 1kg+1m/s=1000g+1m/s) so there was no point in adding the numbers in the first place.
The multiplied value holds its own as an independent value under the change of units.
Likes Delta2
Physical units can have more than one interpretation. One example of the interpretation of m/s is as a velocity, but there can be different examples.
That question is not addressed by mathematics. For example, trigonometry does not tell us that the hypoteneuse of a triangle must be a ladder leaning against a wall. Properties of a ladder leaning against a wall might be analyzed by using trigonometry, but the mathematics of trigonometry does not tell us that only one particular application of trigonometry exists.
Likes sysprog
How do you write √2 * π as repeated addition?
akashpandey said:
Summary:: Why we multiply mass and velocity ?
And not add them ?
If you think of a mass ##M## as being composed of a lot of smaller masses, ##m##, all moving together at some velocity ##v##. Let's say 100 small masses make up the larger mass.
If you add mass and velocity, the the momentum of each component would be ##p = m + v## and the momentum of the whole thing would be ##P = 100(m + v) = 100m + 100v##.
But, if you calculate the momentum of the large mass directly you get ##P = M + v = 100m + v##. And you get a different answer.
Adding two quantities in this way makes no sense.
Whereas, if you multiply quantities, then we have ##p = mv##, and ##P = 100mv = Mv##, and it all makes sense.
Likes Merlin3189 and Ibix
And not add them ?
I think when people started studying motion,they didn't knew that their is quantity momentum which remains conserve but when they started doing maths they found that this quantity mv remains same and they gave name momentum to it.
It would be like saying something like why cucumber is cucumber not orange.
It makes sense formally, but it also has to be useful somehow, which it is because it's conserved.
Take a step backwards. When did you first learn the definition of Multiplication as repeated additions? I suspect it was when you were less than ten years old. Since then, the more advanced concepts of Maths crept into your awareness - even if you never did an advanced Maths Analysis course and you just do it mechanically. However, once you go beyond integers in the application of that definition then you have to introduce implied multiplication and insert that in your 'multiple additions' definition. It has to pull itself up by its own bootstraps - especially when the numbers are not even rational.
The 'rules' about what you are allowed to do about dimensions are pretty straightforward and are actually pretty intuitive. You can multiply different quantities and get a meaningful answer. Amp Hours as the capacity of a battery make sense because you can use the same capacity battery for twice as long by taking half the current etc. etc. etc.. But what would adding possibly 10A to 5H mean? 15 'Somethings'? Equivalent to 1A plus 14H?? Clearly not.
Once you have established the principle of what does and what dean;t make sense then you OP question is answered.
Likes Leo Liu, Ibix and PeroK
The repeated addition thing is not the definition of multiplication. It is the easiest way to teach multiplication to little children who only know addition. The repeated addition thing only even works for multiplication by integers.
  • Wow
Likes PhDeezNutz and Frigus
How could a joke get so many answers?
  • Haha
Likes Hamiltonian, Leo Liu and Chestermiller
That's how mutlipication is defined for positive integers. Multiplication of the rationals and the reals is defined by a systematic generalisation.
Likes etotheipi, Dale and jbriggs444
My whole life was a lie.😕
Likes PeroK
Well, I may be wrong about that. I cannot find an independent definition of real multiplication. So don’t question your life quite yet!
Likes sophiecentaur and Frigus
Well, in the grand scheme of things using dimensional real numbers to quantify things in the physical sciences is really a rather remarkable process. One could argue all day how "intuitive" it is but in the end the real reason is it's observed to work really well.
Likes PhDeezNutz, etotheipi and akashpandey
Addition and multiplication of the rationals is, of course, defined by:
$$\frac a b + \frac c d = \frac {ad + bc}{bd}, \ \ \ \frac a b \times \frac c d = \frac {ac}{bd}$$
Where ##a, b, c, d## are integers, with ##bd \ne 0##.
Multiplication of the Real numbers depends on how you construct them from the rationals. One approach is to define a real number as an equivalence class of sequences of rationals. Then you have to show that if you take two such real numbers, then the product can be well-defined by multiplying the sequences term by term etc.
As has been mentioned before constructing the real numbers from the rationals is a non-trivial exercise.
Likes Stephen Tashi and Dale
PeroK said:
Multiplication of the rationals is, of course, defined by:
ab×cd=ad+bcbd
Where a,b,c,d are integers, with bd≠0.
Well, that is addition. multiplactions is ##\frac{ac}{bd}##.
Likes PeroK
So it is! I better correct it. o:)
Likes martinbn
Even with repeated addition, you are still not adding things with different units.
1 apple x 3 means 1 apple + 1 apple + 1 apple. You are not adding the 3 to the 1.
50 mph *2 hours = (50 mph *1 hour) + (50 mph * 1 hour) = 50 miles + 50 miles = 100 miles
Likes cnh1995 and russ_watters
Ok, I am convinced.
Of course, multiplication of units cannot be identified with either multiplication of reals or integers. It has its own rules and it is just one of those rules that you can multiply disparate units but not add them.
So tell me how else you define multiplication ?
And not add them ?
The short answer to your question is "because we multiply acceleration by mass to get the net force." Consider the following observation (please don't try it at home - it's a thought experiment).
Put your hand flat on a table. Drop on it a 0.5-kg book from a height of 1 meter. You will feel no pain. Now drop a 10-kg lead brick on your hand from the same height. You will fell a lot of pain and probably will have to go to the hospital with a broken hand. The speed ##v## of both objects just before contact with your hand is the same. Why the difference in pain level?
Answer: Each object is stopped by your hand in pretty much the same time interval ##\Delta t##, therefore the acceleration is pretty much the same. However, the net force required to stop the book is much less than the one required to stop the book because the lead brick is 20 times more massive. The more force your flesh and bones are required to exert, the more painful the sensation; if that force exceeds a certain limit, your bones will break.
BTW, I would not question why write ##F_{net}=ma## and not ##F_{net}=m+a## lest Sir Isaac turn over in his grave.
I guess no question is dumb enough to ask ?
Say you need to explain it to 10 years old child and he only nows that multiplication is adding a number repeated time.
So how could you explain him that p=mv and p is not m+v.
p=mv by definition. Even a 10 year old knows that words have definitions.
Adding m+v is against the rules. Even a 10 year old knows that math has rules.
When the inevitable “why” question is asked the answer is that a bunch of scientists and mathematicians agreed to use those definitions and rules because it gave them useful results for the real world.
Likes russ_watters
  • #31
I think this will solve your problem,
Suppose their is a quantity m/v and you named it jake,suresh or any other name and one day someone comes to you and ask why jake or suresh is m/v not mv.
Then how will you answer that?
  • #32
Has anyone pointed out that the net ##mv## in a collision is conserved while the net ##m+v## isn't?
Likes Dale and russ_watters
  • #33
Suppose their is a quantity m/v and you named it jake,suresh or any other name and one day someone comes to you ask why jake or suresh is m/v not mv.
I just don't want to accept the that this is definition that's how it is.
I want to know the real meaning or experiment why it was define that way and not the other.
So just saying this is the definition and accepting it what school does.
Sorry i mean no disrespect to any member of community.
If you guys this question dumb or something else just ignore it.
Likes Lnewqban
  • #34
Try this.
One standard approach has already been described in rough outline.
You start with multiplication of the ordinary positive integers defined in terms of repeated addition. Optionally you add a rule for multiplication by zero.
You extend this to signed integers. There are several ways to do this, but they all yield equivalent results. Perhaps the simplest is to simply say by fiat that positive times positive = positive, positive times negative = negative and negative times negative = positive.
You extend this to rational numbers as in #22 (equivalence classes of ordered pairs of signed integers).
You extend this to real numbers using equivalence classes of Cauchy sequences of rationals. Or Dedekind cuts.
  • #35
Without mathematical rigor, but at a level that is useful to a child who ready to move past integers and the "repeated addition" definition:
##a\times b## is the area of a rectangle with sides of length ##a## and ##b##.
This works as a lie to children because every naif has an intuitive notion of length and area so there's no need to explore the difficulty of formally defining either. Likewise we gloss over the problem of extending the rational numbers to the reals by blithely stating that ##\sqrt{2}\times\pi## is a rectangle with sides of those lengths.
Likes russ_watters, etotheipi and jbriggs444
  • Mechanics
  • Mechanics
