Plutonium88
- 174
Two spheres of mass m and radius r, are released from rest in empty space. The centers of the spheres are separated by a distance R. They end up colliding due to gravitation attraction. Find the magnitude of the impulse just before they collide.
Eg= -Gmm/r
ek= 1/2mv^2
J=F*T
J=ΔP
I first drew my problem out with two frames.
The first frame of the two masses separated by a distance R. The second frame, where they are just about to touch separated by a distance of 2r.
I calculated Change in momentum for both objects.
ΔP1=ΔP2
ΔP1=mV
i found that the change in momentum was reliant upon the final velocity..
Initially when i observe the energy of the two spheres, They are separated by a distance of R, and have no kinetic energy. So if i calculate the Initial energy total for 1 mass, (Which is the same as the other) i get.
Et1= Eg1
Et1= -G*(m^2)/R
In my second frame when i calculate total energy the two spheres are now separated by a distance of 2r. The spheres now have kinetic energy after having moved toward each other..
Et2= Eg2 + Ek2
Et2= -G*((m^2)/2r
Now when i look at this question, i was thinking that it is similar to an orbital question where you have to move an object on the surface to an orbital level and it will have a certain speed... The kinetic energy in a question like that is based on the difference of the First Gravitational Potential Energy Subtract The Second.
I came up with this relation using conservation of energy (i'm assuming no energy is lost cause they are in space and no external forces have acted upon the objects only the conservative force of gravity.)Et1=Et2
Eg1 = Eg2 + Ek2
Ek2= Eg1-Eg2
Ek2 = -G(m^2)/R - (-G(m^2)/2r)
Ek2= G(m^2)/2r - Gm^2/Rso 1/2mv^2 = G(m^2)/2r - Gm^2/R
this leaves me with
V = √(Gm(1/r - 2/R))
so J = ΔP
so J = mV
so J = m*√(Gm(1/r - 2/R))
so j = √(Gm^3(1/r - 2/R))
This is my dilemma... I found a textbook online which has this same question stated, with the answer to the question I'm solving... There answer is different than mine so I'm wondering if some one could point out to me what I'm doing wrong. There answer seems to have 1/2r where i have 1/r and 1/R where i have 2/R...
There answer is:
J = √(Gm^3(1/2r - 1/R))
http://books.google.ca/books?id=Kuh...r centers separated by the distance R&f=false
Question #48 P382 (SHOULD BE A DIRECT LINK)
Anyways i would really appreciate some help cause i can't seem to find where I'm going wrong, and I'm not exactly positive if the textbook answer is even correct, because it is just stated in the question itself... I don't even really have a solid "Answer" to check my answer with other than this one... ^.^
