Momentum-Position vs. Energy-Time Uncertainty Relations
In summary, there are two ways to interpret the momentum-position uncertainty principle in non-relativistic quantum mechanics. The first is that position is a dynamical variable of the particle, while the second treats position as a parameter similar to time. These two interpretations are equivalent, and the latter is similar to the energy-time uncertainty principle. Some textbooks emphasize that these two principles are unrelated, but this may not be the case. The energy-time uncertainty principle can be derived from the time-dependent Schrödinger equation, while the momentum-position uncertainty principle follows from the commutation relation between momentum and position operators. Additionally, the momentum-position uncertainty principle may also hold in relativistic theories.
Logic314
TL;DR Summary
I have read that the uncertainty relation for momentum and position is unrelated to the uncertainty relation for energy and time. But I am confused because when I think about it, the two uncertainty principles actually seem like two sides of the same coin. The "uncertainty in position" can instead be thought of as the spatial delocalization of the wave function, in analogy with the "lifetime" in the energy-time uncertainty relation, which is the temporal delocalization of the wave function.
In a few textbooks in introductory quantum mechanics which I have looked through (e.g. Griffiths), it is heavily emphasized that the momentum-position uncertainty relation has a completely different meaning from the energy-time uncertainty relation, and that they are quite unrelated and only superficially look similar. But I don't see why this is the case. Please let me explain.
From what I know, there are two ways to think about the momentum-position uncertainty principle. One way (which I believe is only valid in non-relativistic quantum mechanics) is that position should be treated as a dynamical variable that is an attribute of the particle. Then, the momentum-position uncertainty principle says that if the probability distribution in the outcome of a position measurement has a standard deviation Δx, then the probability distribution in the outcome of a momentum measurement must have a standard deviation no less than ħ/(2Δx).
But there is another way to think about the momentum-position uncertainty principle. We can treat the position as a parameter similar to time, rather than as an attribute of the particle. Then, the momentum-position uncertainty principle states that if the probability density of detecting a particle at a certain spatiotemporal location has a spatial dependence following a distribution with a standard deviation Δx, then the probability distribution in the outcome of a momentum measurement at that time must have a standard deviation no less than ħ/(2Δx).
As far as I can tell, these two forms of the momentum-position uncertainty principle are equivalent (within the context of non-relativistic quantum mechanics) since if the probability distribution in the outcome of a position measurement has a standard deviation Δx, that precisely means that if one places a particle detector in space, then the probability density that the detector will detect the particle will vary with the position of the detector according to a distribution with standard deviation Δx.
But the second of the above two interpretations of the momentum-position uncertainty principle (which treats position as a parameter) seems strikingly similar in meaning to the energy-time uncertainty principle. The energy-time uncertainty principle states that if the probability density of detecting a particle at a certain spatiotemporal location has a temporal dependence following a distribution with a standard deviation Δt, then the probability distribution in the outcome of an energy measurement must have a standard deviation no less than ħ/(2Δt). Compare this with the momentum-position uncertainty principle, which (as already mentioned) states that if the probability density of detecting a particle at a certain spatiotemporal location has a spatial dependence following a distribution with a standard deviation Δx, then the probability distribution in the outcome of a momentum measurement must have a standard deviation no less than ħ/(2Δx).
It seems that the momentum-position uncertainty principle is indeed totally analogous to the energy-time uncertainty principle since the former has two equivalent formulations (one with position as a dynamical variable, and the other with position as a parameter). Even though time can only be treated as a parameter, the fact that we can always change from treating position as a dynamical variable to treating position as a parameter seems to mean that the two uncertainty principles are actually intimately related, one focusing on the spatial dependence of the wave function and the other focusing on the temporal dependence of the wave function.
But then, what is the point that these textbooks (such as Griffiths) seem to make? Is there any mistake in my argument above? Any clarification is appreciated.
Likes BvU and Demystifier
I want to point out that Griffiths also says on page 114 that in a relativistic theory you would expect the energy-time relation as a "necessary concomitant" to the position-momentum relation.
Griffiths is presenting a non-relativistic theory of QM and he avoids using relativistic arguments. After all, once you have started with the fundamentally non-relativistic SDE, it's not really valid to bring in relativistic arguments here and there.
Likes BvU
You don't need the time dependent Schrödinger equation at all to show that the p-x-uncertainty relation holds. It follows from the commutation relation of ##\hat{p}## and ##\hat{x}##.
The energy-time uncertainty follows from the TDSE and practically says that if a quantum state is a mixture of many energy eigenstates, then the position and momentum space wavefunctions change quickly so that the probability densities become something else in a short time. In the opposite situation, the probability density ##|\psi (x)|^2## of a one-particle wavefunction remains constant if ##\psi## is an energy eigenstate.
Likes BvU
In your interpretation of time uncertainty, you need something like probability density ##\rho(t)## or ##\rho(x,t)## as a function of time or spacetime. This probability density has to satisfy a normalization condition
$$\int_{-\infty}^{\infty} dt \, \rho(t) =1$$
or
$$\int_{-\infty}^{\infty} dt \int d^3x \, \rho(x,t) =1$$
In quantum mechanics, the probability density is expected to be something like
$$\rho(x,t) =|\psi(x,t)|^2$$
so the normalization condition should be something like
$$\int_{-\infty}^{\infty} dt \int d^3x \, |\psi(x,t)|^2 =1$$
All this seems innocent, but here is the problem. When ##\psi(x,t)## is a solution of the Schrodinger equation, then in fact
$$\int d^3x \, |\psi(x,t)|^2 ={\rm constant}$$
so
$$\int_{-\infty}^{\infty} dt \int d^3x \, |\psi(x,t)|^2 ={\rm constant}\int_{-\infty}^{\infty} dt =\infty$$
Hence the wannabe probability density ##\rho(x,t) =|\psi(x,t)|^2## cannot be properly normalized. A possible way out is to consider a finite region of time which gives
$$\int_{t_1}^{t_2} dt ={\rm finite}$$
but most physicists don't find it very appealing.
Likes BvU and PeroK
You can also define an autocorrelation function ##C(t) = \langle \psi(0)|\psi (t)\rangle## and follow how quickly it approaches 0 when time passes.
Momentum can change while Energy stays the same.
How does this relate to the topic of this thread?
It's completely irrelevant but the opposite is also possible, e.g. when you fall down with a parachute. :smile:
The time-energy uncertainty relation is indeed different in nature from the usual uncertainty relation concerning observables since in QT time is not an observable at all. For the same reason it's such a conceptually complicated issue to precisely define the "tunnel time" of particles through a potential barrier.
Is there some sort of symmetry between Et and px? What would be the conserved quantity?
I don't know what Et and px mean. Energy and momentum are conserved quantities for closed systems within Newtonian and special relativistic physics because both spacetime models include temporal and spatial homogeneity (invariance of the natural laws under translations in space and time).
Related to Momentum-Position vs. Energy-Time Uncertainty Relations
1. What is the uncertainty principle?
The uncertainty principle, also known as Heisenberg's uncertainty principle, is a fundamental principle in quantum mechanics that states that it is impossible to simultaneously know the exact momentum and position of a particle, as well as the exact energy and time of a particle. This is due to the inherent uncertainty and unpredictability of quantum systems.
2. What is the relationship between momentum-position and energy-time uncertainty?
The momentum-position uncertainty relation and the energy-time uncertainty relation are two different formulations of the uncertainty principle. The momentum-position uncertainty relation states that the more precisely we know the momentum of a particle, the less precisely we can know its position, and vice versa. Similarly, the energy-time uncertainty relation states that the more precisely we know the energy of a particle, the less precisely we can know its time, and vice versa.
3. How do these uncertainty relations affect our understanding of the physical world?
The uncertainty principle has significant implications for our understanding of the physical world, as it challenges the classical notion of determinism. It suggests that at the quantum level, the behavior of particles is inherently probabilistic and unpredictable. This has led to the development of new theories and interpretations in quantum mechanics, such as the Copenhagen interpretation and the Many-Worlds interpretation.
4. Can the uncertainty principle be violated?
No, the uncertainty principle is a fundamental principle in quantum mechanics and has been extensively tested and confirmed through experiments. It is a fundamental limitation of our ability to measure and understand the behavior of particles at the quantum level.
5. How is the uncertainty principle related to the wave-particle duality?
The uncertainty principle is closely related to the wave-particle duality of quantum objects. It suggests that particles can exhibit both wave-like and particle-like behavior, and the more we know about one aspect (such as its position), the less we know about the other aspect (such as its momentum). This duality is a fundamental aspect of quantum mechanics and is essential to understanding the behavior of particles at the quantum level.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
