Momentum problem driving me crazy.
  • Thread starter Demondo
  • Tags
    Momentum
In summary, a 7g bullet fired from a gun into a 1kg block of wood held in a vise will penetrate the block to a depth of 8cm. If the block is placed on a frictionless horizontal surface, a second 7g bullet will also penetrate the block to a depth of 8cm.
Demondo
I asked this on IRC but with only 7 people there, including myself, I'm not too confident I'll get an answer anyway...
A 7g bulet, when fired from a gun into a 1kg block of wood held in a vise, penetrates the block to a depth of 8cm. What If? This block of wood is placed on a frictionless horizontal surface, and a second 7g bullet is fired from the gun into the block. To what depth will the bullet penetrate the block in this case?
It seems like such an odd question because you aren't given the bullet's speed. Anyone have any idea what would happen? It is possible that the bullet would push the block, but that just doesn't seem likely at all because of it's speed. Or it could puncture just as deeply, but this time the block moves. But I'm really uncertain about what happens. Any help would be appraicted. :smile:
Impulse... I think the bullet still goes in regardless... Probably not as deep or will not penetrate it... It will be a perfect inelastic collision where the 2 masses become one...
Say... If someone where to shoot you with a paintball gun in the face and you had your mask on... You would get paint all over your face. If you were to stand on ice or some frictionless surface and the same situation occured... You still get paint over your face and a fun slide in the direction of the paintball...
Thats what I think at least...
If you make a few simplifying assumptions, the problem is straightforward.
With the wood in the vise, all the kinetic energy of the bullet goes into penetrating the wood and thus is transformed into thermal energy. We'll make the simplifying assumption that the force between the bullet and wood is uniform: thus the given KE of the bullet leads to the given penetration, FxD = ΔKE.
With the wood free to move, assume that the bullet will again penetrate the wood making the collision perfectly inelastic. (Not unreasonable.) Apply conservation of momentum to get the speed of the block plus bullet post collision, then use that speed to calculate its KE. Now find the ΔKE during the collision--that's the energy used to penetrate the wood. In this case the penetration is less because some of the bullet's energy is used to accelerate the wood.
FAQ: Momentum problem driving me crazy.
What is momentum?
Momentum is a physical quantity that describes an object's motion and its resistance to changes in that motion. It is calculated by multiplying an object's mass by its velocity.
How is momentum related to driving?
In driving, momentum is important because it determines how much force is needed to change the motion of a vehicle. The heavier and faster a vehicle is moving, the more momentum it has and the more force is needed to stop or change its direction.
How does momentum affect braking?
Momentum plays a crucial role in braking as it determines the distance and force needed to stop a vehicle. The greater the momentum, the longer it will take to come to a stop and the more force will be needed to do so.
Can momentum be conserved in a collision?
Yes, according to the law of conservation of momentum, the total momentum of a closed system (such as two colliding objects) remains constant before and after a collision. This means that the total momentum of the objects involved in the collision will equal the total momentum after the collision.
How can momentum be managed while driving?
Momentum can be managed while driving by maintaining a safe speed, avoiding sudden changes in direction or speed, and using proper braking techniques. It is also important to be aware of the weight and speed of your vehicle and adjust your driving accordingly.
