- #36
timetraveller123
- 621
- 45
oh then vi = wir? why are you asking that
So combine that with your first two equations in post #34.vishnu 73 said:oh then vi = wir? why are you asking that
I'm not assuming it transits immediately to rolling. I am trying to find out if that is possible.vishnu 73 said:no but aren't you assuming it transits immediately to pure rolling ? as the impulses we denoted in post #34 are only when the ball hits the ground which is a very short time
Yes, that all looks good. It should give you the relationship between μ, vx and vy which allows instantaneous transition to rolling.vishnu 73 said:ok i kind of get what you are saying now so i did this:
no more vf and wf and t
mvx = Jx = mwir
mwir = Jx r2m/I
solving for Jx i got
Jx = 2mvx/7
then what the other equation we have is
jx ≤ μJv am i supposed to use this
is what i did correct
If we can show the transition is instantaneous upon landing, how long does the transition take?vishnu 73 said:how are we even supposed to find time from that equations
Quite so, but you asked how we would find time.vishnu 73 said:isn't that instantaneous?
An impact like this takes an unknowable time and generates unknowable forces. All we can know is the impulse, mΔv=∫F.dt. The elapsed time is assumed arbitrarily short, effectively zero. That is what instantaneous means. If the frictional impulse during the impact is sufficient to lead to rolling contact then the answer to the question is zero.vishnu 73 said:how do you derive time from these equations the only thing i see the impulse term having time as force * time but what is force help me please!
Yes, that's it.vishnu 73 said:but the answer given in the brilliant org was 1/15 sec but i think i trust you more
so you are saying that if Jx = Jvμ then there is instantaneous transition to pure rolling
so since Jx here is 2mvx /7 ≤μmvy hence there is immediate transition to pure rolling
is my understanding correct
Yes.vishnu 73 said:so before each problem i should check whether the impulse is enough to cause pure rolling instantly?
It is common to regard the velocity of the mass centre as constituting translational KE, with any other motional energy considered rotational. But there other ways of considering it. A rolling disk or ball is, at each instant, rotating about its point of contact with the ground. Thus, it could all be considered rotational energy.vishnu 73 said:ok i have a few more questions not related to this thread but going to post them as they are just trivial doubts
ok so if ball is rolling down a hill we say it has rotational and translational kinetic energy but when a disk is spinning about its axis we only say it has rotational kinetic energy why is that so?
No, as I wrote, it can be viewed either way. The total KE is the same.vishnu 73 said:so it is just that about the instantaneous center i only regard the rotational energy?
That's different. There is no rotational KE here since no rigid body is rotating.vishnu 73 said:then what is energy of the Earth around the sun ignoring Earth's spin on its own axis
At root, the KE of a system is simply ∑½mivi2, where the sum is taken over infinitesimal mass elements. Each such element is considered so small as to have no significant rotational KE.vishnu 73 said:wait what is rigid body i mean is there a formal definition for a rigid body?
are you saying it does not have rotational KE because the sun and the Earth are not connected?
So, the ball is rolling to the right, say, and we yank the paper suddenly to the left.vishnu 73 said:say a ball is rolling on table (pure rolling) then it enters a paper on the table and continues to pure roll
then we suddenly pull the paper opposite to direction of the motion of the ball
can you please explain what exactly is happening to the ball when we suddenly pull the paper?
In that case we do not immediately know what the frictional force is. Instead, we know the relationship between the frictional force and the ball's linear acceleration, the relationship between the frictional force snd the angular acceleration, and the relationship between those two accelerations given that it continues to roll without slipping. Three equations, three unknowns.vishnu 73 said:ok say we pull it slowly then what happens
There are several impossibilities in the specification of this question. I would not waste any time on it.neilparker62 said:If both spheres have the same radius, then I dont' see how there can be any transfer of momentum to cause 'oblique projectile motion'. It seems to me the only way this can happen is if the 1m mass actually has a larger radius than the 2m mass such that the line of collision is also 'oblique' allowing for a vertical component in the momentum transfer. The 1m mass 'jumps' when it hits the 2m mass.
