Momentum - Throwing coal out of railroad car
In summary, a railroad hopper car with a mass of 50000 kg and containing 30000 kg of coal coasts along the track at 8 m/s. After the coal is released onto a platform over a period of 4 seconds, the car continues to travel at 8 m/s. The horizontal impulse delivered to the coal by the platform is 240000 and the average horizontal force on the platform is 48000. If the coal is thrown backwards from the car with a velocity of zero, the final speed of the car remains at 8 m/s according to the principle of conservation of momentum.
Bryon
99
A railroad hopper car has a mass of 50000 kg when empty and contains 30000 kg of coal. As it coasts along the track at 8 m/s the hopper opens and steadily releases all the coal onto a platform below the rails over a period of 4 s.
How fast does the car travel after all the coal is dumped? 8m/s
What is the horizontal impulse delivered to coal by the platform? 240000
If the coal comes to rest 1 second after the dumping is finished, what was the average horizontal force on the platform? 48000
Let's say that instead of the coal falling out of the bottom of the coal car, some very strong physics student threw it backwards from the car, so that the velocity of each piece of coal was zero just after it left her shovel. How fast does the car travel after all the coal is thrown instead of dumped? ? Clueless.
0.5(Total weight)v^2 = 0.5*(80000)*8^2 = 2560000
0.5(Weight of coal)v^2 = ??
0.5(Weight of car)v^2 = ??
m(coal)v(coal) + m(car empty)v(initial) = m(car + coal)v(initial)
This should be:
m(coal)v(coal final) + m(car empty)v(car final) = m(car + coal)v(initial)
You know everything except the final speed of the car.
Would the final speed of the coal be found using this:
m*g = 0.5*m*v^2?
m*g = 0.5*m*v^2?
you can do everything with conservation of momentum and you certainly don't need g. You only need the equation you already nearly posted correctly/
I got it! Thanks. What threw me off was that the velocity of the coal was zero.
Related to Momentum - Throwing coal out of railroad car
1. What is momentum?
Momentum is a measure of an object's motion, taking into account its mass and velocity. It is often described as the "quantity of motion" an object has.
2. How is momentum calculated?
Momentum is calculated by multiplying the mass of an object by its velocity. The formula for momentum is p = m * v, where p is momentum, m is mass, and v is velocity.
3. Why does throwing coal out of a railroad car affect its momentum?
Throwing coal out of a railroad car affects its momentum because it changes the mass and velocity of the car. By throwing coal out, the mass of the car decreases, which in turn affects its momentum. Additionally, the force of throwing the coal also changes the velocity of the car.
4. How does throwing coal out of a railroad car affect its speed?
Throwing coal out of a railroad car will cause the car to slow down. This is because the decrease in mass decreases the car's momentum, which is directly related to its speed. As momentum decreases, so does the car's speed.
5. Is momentum conserved in this scenario?
Yes, momentum is conserved in this scenario. According to the law of conservation of momentum, the total momentum of a system remains constant unless acted upon by an external force. In this case, the external force is the act of throwing coal out of the railroad car, but the total momentum of the system (the car and the thrown coal) remains the same.
