Monitoring calls from Z.exe to foo() in Y.sys, a driver
  • Thread starter Superposed_Cat
In summary: I think the Visual Studio debugger is the most common one used these days.In summary, the conversation discusses how to find and return the name of a specific function in a driver for a USB device. The solution involves using a debugger and setting a breakpoint at the beginning of the function. The conversation also mentions resources for debugging tools and asks for confirmation on their current support.
Superposed_Cat
388
Say I write a driver for my usb device X containing a function foo(), and save it in c:/windows/system32/Y.sys, now i have a program Z.exe that I start up, it accesses X via Y.sys and calls foo(), how can I attack to Z.exe and look for any api calls to mydriver.sys specifically and return the name? I have googled but can't find any info that specifically looks for calls from Z to Y and returns foo's name if foo isn't a built in win32 library call. Any help appreciated.
Technology news on Phys.org
Since you wrote the code for Y.sys (or is it mydriver.sys?), can't you put a debugger breakpoint at the first line in foo()? I don't have any experience debugging drivers, so this might not be the advice you're looking for.
I did not write it myself, it came with the device, I seek to mod a specific function in the driver,
Do you have the source code? If so, build your project in a debugger, with a breakpoint at the beginning of the function you're interested in.
Tom.G said:
There at least used to be a way using Windows debuggers, don't know if it is still supported.
I'm pretty sure those debuggers are still supported.
Related to Monitoring calls from Z.exe to foo() in Y.sys, a driver
1. How does monitoring calls from Z.exe to foo() in Y.sys work?
Monitoring calls from Z.exe to foo() in Y.sys involves setting up a system to intercept and track the communication between the two components. This can be done through various methods such as using debugging tools or creating custom monitoring software.
2. Why is it important to monitor these calls?
Monitoring calls from Z.exe to foo() in Y.sys can provide valuable insights into the behavior and performance of the driver. It can also help identify any potential issues or bugs that may arise from the interaction between the two components.
3. What tools are commonly used for monitoring calls in a driver?
There are various tools and techniques that can be used for monitoring calls in a driver, including debugging tools such as WinDbg and Visual Studio, as well as custom monitoring software specifically designed for this purpose.
4. Can monitoring calls from Z.exe to foo() in Y.sys impact system performance?
In most cases, monitoring calls from Z.exe to foo() in Y.sys should not have a significant impact on system performance. However, if the monitoring process is not optimized or the system is already under heavy load, it may cause a slight decrease in performance.
5. How can the data collected from monitoring calls be used?
The data collected from monitoring calls can be used for various purposes, such as troubleshooting issues, optimizing system performance, and identifying potential security vulnerabilities. It can also be used for research and analysis purposes to gain a better understanding of the communication between the driver and the executable.
11K
  • Computing and Technology
