Mono and polycristallin material
  • Thread starter physicist888
  • Tags
    Material
In summary, the conversation discusses the differences between monocrystalline and polycrystalline materials, as well as the connection between polymers and nanoparticles in nanocomposites. The specific topic being studied is a thin film made of diamond-like carbon-metal nanocomposite, which can have varying properties depending on its size and composition. There is confusion about whether such nanocomposites are considered ceramics, metals, or semiconductors.
physicist888
63
hi everybody
i would like to know what's the different between a mono and a polycristallin material.
And if we are speaking about nanocomposite, what's the link beteween poly and the nanoparticls ?
thanks for all
A monocrystalline solid is a single crystal; the crystal orientation at any two points, be they separated by microns or meters, is the same. All other solids are polycrystalline (multiple crystals separated by grain boundaries) or amorphous (no apparent ordering). The distinction between a polycrystalline material with extremely small grains and an amorphous material is arbitrary.
A composite can contain all three types. Is there a particular material you're studying?
yes actually, I am studyin a thin films made of diamond like carbon-metal nanocomposite. So its a carbon cabrid. But i was cheking up about the application of such nanocrystalline and i didnt find out more things about. I mean, a such nanoparticle could be semiconductor? or metallic? all I've found that a such nanocomposite is called ceramic. And it could be a metal or a semiconductor, actually that depends on his size. bu i didnt get it well.
Thanks for your explanation
Related to Mono and polycristallin material
1. What is the difference between mono and polycrystalline material?
Mono and polycrystalline materials are both types of solid materials with a crystalline structure. The main difference between the two is the arrangement of their crystal structures. Mono means "one," so monocrystalline materials have a single, continuous crystal structure with no grain boundaries. Polycrystalline materials, on the other hand, have multiple smaller crystals that are randomly oriented and separated by grain boundaries.
2. Which type of material is more commonly used in industrial applications?
Both mono and polycrystalline materials have their own advantages and applications. However, polycrystalline materials are more commonly used in industrial applications due to their lower cost and easier manufacturing process. Monocrystalline materials are often used in specialized applications, such as in electronics and solar cells.
3. What are the main advantages of monocrystalline materials?
Monocrystalline materials have a more uniform and consistent structure, which results in better mechanical and electrical properties. They also have a higher purity compared to polycrystalline materials, making them ideal for applications that require high precision and reliability.
4. How do the properties of mono and polycrystalline materials differ?
The properties of mono and polycrystalline materials differ mainly due to their crystal structure. Monocrystalline materials have higher strength, better electrical conductivity, and lower thermal expansion compared to polycrystalline materials. However, polycrystalline materials have higher fracture toughness and are less prone to cracking compared to monocrystalline materials.
5. Can mono and polycrystalline materials be used interchangeably?
No, mono and polycrystalline materials cannot be used interchangeably as they have different properties and applications. Monocrystalline materials are often used in specialized and high-tech applications, while polycrystalline materials are more suitable for industrial and commercial purposes. Using the wrong type of material can result in subpar performance and potential failure of the product or system.
