Monochromatic Light and a Prism
In summary: Using the law of cosines, we can find the angle of reflection, φ3: φ1 + φ3 = 90 degrees. Since φ2 = φ3 - φ1, we can conclude that φ2 = 45 degrees.
Gee Wiz
137
Red light is incident in air on a 30o - 60o - 90 o prism as shown. The incident beam is directed at an angle of φ1 = 47.6o with respect to the horizontal and enters the prism at a height h = 11 cm above the base. The beam leaves the prism to the air at a distance d = 27.6 cm along the base as shown.
What is φ1,max, the maximum value of φ1 for which the incident beam experiences total internal reflection at the horizontal face of the prism?
Snell's law n1*sin(θ1)=n2*sin(θ2)
Okay, so I started by trying to find the angle (for angle two) for which all the light would be reflected. To find this, I know that the refracted angle will be 90°. Therefore, i think to find this angle it would just be sin^-1(n1/n2). (I used n1 to refer to the air=1, and n2 for the prism which i solved for earlier and got 1.5725). I believe if i take the complement of this angle i would get φ2. I don't really know how to go from here, or even if i did the above correctly.
https://www.smartphysics.com/Content/Media/Images/EM/25/h25_prism.png
That looks right for φ2. Now use some geometry. There's a triangle base d with its apex where the light enters. What's the angle in that apex?
I don't know what apex your referring to...the other side of the phi 2 line at the top? that's just the same as phi 2
Well, so i know that the angle that the light enters the prism is with respect to the normal line. So, I tried to figure out the inside (refracted) angle in the prism. If i move H over to wear the light enters i find that top angle is 60 degrees.
Say the light enters at point A, leaves at point B, and the 30 degree angle is point C. Then in the triangle ABC (of which A is the apex) you know two of the three angles.
Okay well the angle at A is just 180-30-phi2
Right, and you've calculated φ2 already. How does the angle at A relate to φ1?
I think it would be equal? Because of some geometry principal that i don't remember the name of..or i just made up
edit:wait no let me think about more
Well i thought it would be 180-99.48 (value i got for angle A) - 30 degrees..but that's not right
If the angle at A is 99.48 degrees, what angle is the light ray making to the normal (within the prism) at A?
I believe it would be 99.48-90 = 9.48
Right. And what relationship does that have to the angle to the normal at which the light ray originally struck the prism?
Snell's law n1*sin(θ1)=n2*sin(θ2).
I do that and get about 15 degrees. Then how do i find the angle phi1 with respect to the horizontal?...I tried adding/subtracting from the original given value...(which yes doesn't make sense). Ahhhhh! I got it. I wasn't really thinking, i should have use the supplementary relationship between the normal 30 and then the deduced 60. So, then i take 60-15 and get the correct phi 1.
Thank you very much, i really appreciate the help
You're welcome.
Question
I follow up to how you got 9.48. I have different numbers for my question. I understand snells Law, but I don't know how you got the angle to be about 15 degrees. Can you explain how you got to that number?
Snell's law, using the correct index of refractions
FAQ: Monochromatic Light and a Prism
1. What is monochromatic light?
Monochromatic light refers to light that consists of a single wavelength or color. It is often produced by lasers and is characterized by its pure and uniform color appearance.
2. What is a prism?
A prism is a transparent optical element with flat, polished surfaces that can refract or bend light. It is typically made of glass or plastic and is used to split white light into its component colors.
3. How does a prism work?
A prism works by refracting or bending light as it passes through the different materials and angles of the prism. This causes the different wavelengths of light to be dispersed, creating a spectrum of colors.
4. What is the relationship between monochromatic light and a prism?
A prism is commonly used to separate white light into its component colors, including monochromatic light. This allows scientists to study and manipulate specific wavelengths of light for various experiments and applications.
5. What are some practical applications of monochromatic light and a prism?
Monochromatic light and prisms have a variety of practical applications, including in spectroscopy, photography, and telecommunications. They are also used in scientific research, such as in the study of atomic and molecular structure.
