Monotonically increasing/decreasing functions
  • Thread starter gliteringstar
  • Tags
    Functions
In summary, we discussed different methods for determining whether a function expressed in terms of another function is increasing or decreasing. One way is to take the derivative and set it equal to 0, while the other way is to consider h(x+a) - h(x) and show that it is positive. However, more information about f(x) may be needed to solve this problem.
gliteringstar
whenever a function is expressed in terms of another function,how do we find whether the function is increasing or decreasing?
say ,for example ,we have :
h(x)= f(2x)+f(x)
pls tell anyone,what procedure we need to follow to find whether the above given function is increasing/monotonically increasing or decreasing/monotonically decreasing.thanks !
Mathematics news on Phys.org
There are two ways that I can think of. Assuming that the function is continuously differentiable, take the derivative and set equal to 0. Make a number line and test a point between every 0 to see if it's increasing or decreasing. Also, if there is no zero, then you have a monotonic increasing/decreasing function automatically.
Assuming your function is h(x), the other way is to consider h(x+a) - h(x), where a is an arbitrary positive number. If you can show that h(x+a) - h(x) is positive, then h is monotonically increasing.
To show that [itex]f[/itex] is monotonically increasing, we need to show that for any [itex]\Delta{x} > 0[/itex], [itex]f(x + \Delta{x}) > f(x)[/itex] for all [itex]x[/itex] in the domain; or equivalently, [itex]f(x + \Delta{x}) - f(x) > 0[/itex]. An equivalent definition is that [itex]f(x_1) < f(x_2)[/itex] for all [itex]x_1, x_2[/itex] in the domain of [itex]f[/itex] with [itex]x_1 < x_2[/itex].
For your problem, try to evaluate [itex]h(x + \Delta{x}) - h(x)[/itex] with the assumption [itex]f(x + \Delta{x}) > f(x)[/itex].
But I think you need more information about [itex]f(x)[/itex] to solve this.
Related to Monotonically increasing/decreasing functions
1. What is a monotonically increasing/decreasing function?
A monotonically increasing function is a function that always increases in value or remains constant as the independent variable increases. A monotonically decreasing function, on the other hand, always decreases in value or remains constant as the independent variable increases.
2. How can you determine if a function is monotonically increasing/decreasing?
To determine if a function is monotonically increasing/decreasing, you can plot the function on a graph and observe the trend of the graph. Alternatively, you can calculate the derivative of the function and check if it is always positive (for increasing) or always negative (for decreasing).
3. What is the difference between a strictly monotonically increasing/decreasing function and a non-strictly monotonically increasing/decreasing function?
A strictly monotonically increasing/decreasing function is one where the values strictly increase or decrease without any constant intervals. In a non-strictly monotonically increasing/decreasing function, the values may increase or decrease by constant intervals.
4. Can a function be both monotonically increasing and decreasing?
No, a function cannot be both monotonically increasing and decreasing. A function can only be monotonically increasing or decreasing, but not both at the same time.
5. What is the significance of monotonically increasing/decreasing functions in mathematics and science?
Monotonically increasing/decreasing functions are important in mathematics and science as they help us understand the behavior of variables and their relationship with one another. These functions are used in various fields, such as economics, physics, and engineering, to model real-world phenomena and make predictions.
