Monotonous functions and asymptotes
  • Thread starter Dragonfall
  • Tags
    Functions
In summary, the homework statement is that if f(x) tends to zero monotonically as x increases without limit, and is continuous for x>0, and of the series \sum_{k=1}^{\infty}f(k) diverges, then \sum_{k=1}^nf(k) \sim \int_1^nf(x)dx. Michel claims that by monotonicity he can conclude that \frac{\int_1^nf(x+1)dx}{\sum_{k=1}^nf(k)}\le1\le\frac{f(1)+\int_1^nf(x)dx}{
Dragonfall
1,030
Show that if [tex]f(x)[/tex] tends to zero monotonically as x increases without limit, and is continuous for x>0, and of the series [tex]\sum_{k=1}^{\infty}f(k)[/tex] diverges, then [tex]\sum_{k=1}^nf(k) \sim \int_1^nf(x)dx[/tex].
If g(x) is a second function satisfying the same hypotheses as f(x), and if g(x)=o(f(x)), show that
[tex]\sum_{k=1}^ng(k)=o(\sum_{k=1}^nf(k)_[/tex].
I think by monotonicity we can conclude that
[tex]\frac{\int_1^nf(x+1)dx}{\sum_{k=1}^nf(k)}\le1\le\frac{f(1)+\int_1^nf(x)dx}{\sum_{k=1}^nf(k)}[/tex]
And I want to show that LHS and RHS converge to each other, hence they both converge to 1. But I can't get it to work.
The second part I don't know what to do.
I think you have to restate the problem. How does n enter the picture?
Dragonfall,
I have two questions to understand your question:
Do you really mean that [tex]\sum_{k=1}^{\infty}f(k)[/tex] diverges ?
What do you mean by [tex]\sum_{k=1}^\infty f(k) \sim \int_1^nf(x)dx[/tex], what is the meaning of the symbol [tex]\sim[/tex] ?
Otherwise I have the feeling that a correspondance between a series and an integral can always be established by considering some ad-hoc step function. The properties could then be derived by considering some relations between the step function and the continuous function. In your case, with the given hypothesis, you can easily find two step functions majoring and minoring the integral.
michel
[tex]\sim[/tex] Means the quotient of the two, in the limit of infinity, is equal to 1. Note: Just because the quotient of the two is 1, it does not mean they are equal, even in the limit.
Eg [tex]x \sim x+1[/tex], but the difference is always constant and they are never equal.
In long terms, he's saying
[tex]\lim_{n\to\infty} \frac{\sum_{k=1}^\infty f(k)}{\int_1^nf(x)dx}[/tex]
Are you sure the limiting variable is n? n Doesn't appear in that quotient, hence it is a constant.
The problem needs to be restated.
Yes it does appear in the quotient, look at the bounds on the integral..
I meant the numerator. My bad.
No its just that before the original sum was [tex]\sum_{k=1}^n f(k)[/tex], and the limit makes that to infinity.
If it make anyone happy:
[tex]\frac{\sum_{k=1}^\infty f(k)}{\int_1^{\infty} f(x) dx}[/tex]
Hum!
[tex]\sum_{k=1}^{\infty}f(k)[/tex] doesn't even exist according to our hypothesis. Someone is being sloppy with notation.
It wasn't me! I was just copying down whatever he said and explained what the ~ meant!
Perhaps it would be better to say
[tex]\lim_{n\rightarrow \infty}\frac{\Sigma_{k=1}^n f(k)}{\int_1^n f(x)dx}= 1[/tex]
I believe that's the same thing.
Dragonfall, consider how the Riemann sum
[tex]\sum_{i=1}^n f(a+ i\Delta n)\Delta n[/itex]
a an integer compares with f((a).
I'm not sure it's necessary to look at that sum, since f(x) is monotone decreasing we already have that
[tex]\sum_{k=1}^nf(k)\le\int_1^nf(x)dx+f(1)[/tex],
and a similar bound from below. My question is whether
[tex]\frac{\int_1^nf(x+1)dx}{\sum_{k=1}^nf(k)}\rightarrow\frac{f(1)+\int_1^nf(x)dx}{\sum_{k=1}^nf(k)}[/tex]
as n goes to infty, and second if
[tex]f(x)\le a\le g(x)[/tex]
for all x and that as x increases [tex]f\rightarrow g[/tex] and [tex]g\rightarrow f[/tex], then [tex]f\rightarrow a[/tex]?
FAQ: Monotonous functions and asymptotes
What is a monotonous function?
A monotonous function is a mathematical function that either increases or decreases consistently and does not have any sudden changes in direction.
What is an asymptote?
An asymptote is a line that a graph approaches but never touches. It can be horizontal, vertical, or oblique.
How do you determine if a function is monotonous?
A function is monotonous if its derivative is either always positive or always negative. This means that the function is either always increasing or always decreasing.
What is the importance of asymptotes in mathematics?
Asymptotes help us understand the behavior of a function as it approaches certain values. They also help us determine the domain and range of a function.
Can a function have multiple asymptotes?
Yes, a function can have multiple asymptotes. It is possible to have both horizontal and vertical asymptotes for a single function.
