A Monte Carlo simulation for the classical isotropic 3D Heisenberg model
The discussion presents a Python implementation of a Monte Carlo simulation for the classical isotropic 3D Heisenberg model. Key functions include initializing spin configurations, performing Metropolis algorithm updates, and calculating magnetization and susceptibility. The simulation runs over a specified temperature range, collecting average magnetization and susceptibility data. Results are visualized through plots of susceptibility and magnetization against temperature. The implementation aims to explore the thermodynamic properties of the Heisenberg model effectively.
IWantToLearn
TL;DR Summary
I am trying build a monte Carlo simulation for the classical isotropic 3D Heisenberg model, I used Metropolis algorithm, but the results doesn't make sense and do not show phase transition
here is my attempt to implement using python
Python:
import numpy as np
import matplotlib.pyplot as plt
def initialize_spins(L):
    """Initialize a random spin configuration with unit magnitudes."""
    spins = np.random.normal(size=(L, L, L, 3))
    magnitudes = np.linalg.norm(spins, axis=-1, keepdims=True)  # Calculate magnitudes
    spins /= magnitudes  # Normalize spins to unit magnitudes
    return spins
def metropolis_step(spins, J, k_B, T):
    """Perform one Metropolis algorithm update step."""
    L = spins.shape[0]
    i, j, k = np.random.randint(0, L, size=3)
    spin = spins[i, j, k]
    # Calculate the initial energy difference
    neighbors = [
        spins[(i+1)%L, j, k], spins[(i-1)%L, j, k],
        spins[i, (j+1)%L, k], spins[i, (j-1)%L, k],
        spins[i, j, (k+1)%L], spins[i, j, (k-1)%L]
    initial_energy = -2 * J * np.dot(spin, np.sum(neighbors, axis=0))
    # Flip the spin
    spin *= -1
    # Calculate the final energy difference
    final_energy = -2 * J * np.dot(spin, np.sum(neighbors, axis=0))
    # Calculate the energy difference
    dE = final_energy - initial_energy
    # Metropolis acceptance criteria
    if dE <= 0 or np.random.rand() < np.exp(-dE / (k_B * T)):
        spins[i, j, k] = spin
    return spins
def calculate_magnetization(spins):
    """Calculate the magnetization per spin."""
    magnetization_sum = np.sum(spins, axis=(0, 1, 2))  # Sum all spin vectors
    magnetization = np.linalg.norm(magnetization_sum)  # Calculate the magnitude of the sum
    return magnetization
def calculate_susceptibility(magnetizations):
    """Calculate the susceptibility (variance of magnetization per spin)."""
    return np.var(magnetizations)
L = 10
J = 1.0
k_B = 1.0
sweep = L**3
num_steps = 1000000
equilibration_steps = 100000
T_min = 0.1
T_max = 2.5
T_step = 0.1
temperature_range = np.arange(T_min, T_max + T_step, T_step)
susceptibilities = []
avg_magnetizations_per_spin = []
def run_simulation(L, J, k_B, T, num_steps, equilibration_steps):
    """Run the Monte Carlo simulation for the isotropic 3D Heisenberg model."""
    spins = initialize_spins(L)
    magnetizations = []
    for step in range(num_steps):
        spins = metropolis_step(spins, J, k_B, T)
        if step >= equilibration_steps:
            if step % sweep == 0:
                # Calculate and append the average magnetization per spin
                magnetization = calculate_magnetization(spins)
                magnetizations.append(magnetization)
    avg_magnetization_per_spin = np.mean(magnetizations)
    avg_magnetization_per_spin /= L ** 3
    susceptibility = calculate_susceptibility(magnetizations)
    return avg_magnetization_per_spin, susceptibility
for T in temperature_range:
    avg_magnetization_per_spin, susceptibility = run_simulation(L, J, k_B, T, num_steps, equilibration_steps)
    avg_magnetizations_per_spin.append(avg_magnetization_per_spin)
    susceptibilities.append(susceptibility)
    print("Temperature: {:.2f} K, Average Magnetization per Spin: {:.4f}, Susceptibility: {:.8f}".format(T, avg_magnetization_per_spin, susceptibility))
# Plot susceptibility vs temperature
plt.plot(temperature_range, susceptibilities)
plt.xlabel("T (K)")
plt.ylabel("𝜒")  # Greek letter chi (MATHEMATICAL ITALIC SMALL CHI)
plt.title("Susceptibility vs. Temperature")
plt.grid(True)
plt.show()
# Plot magnetization vs temperature
plt.plot(temperature_range, avg_magnetizations_per_spin)
plt.xlabel("T (K)")
plt.ylabel("<M>/L³")  # <M>/L^3 with superscript 3
plt.title("Magnetization vs. Temperature")
plt.grid(True)
plt.show()
Mentor's Note: Code tags added.
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
