More elegant way to solve divergence of arbitrary dotproduct
In summary, the conversation discusses two cases of computing the divergence of a vector field, one with a dot product and one with a cross product. The speaker mentions that they find it tedious and vague to solve these types of exercises and wonders if there are any tricks or shortcuts. They are directed to use the divergence formula in cylindrical or spherical coordinate systems and find vector calculus identities for these types of problems. The speaker also clarifies that the vector field only depends on the variable r and has one component, making the derivation simpler.
maxknrd
This is more of a general question, but I've encountered this kind of exercises a lot in my current preperations for my exam:
There are two cases but the excercise is pretty much the same:
Compute
$$(1) \space \operatorname{div}\vec{A}(\vec{r}) \qquad , where \thinspace \vec{A}(\vec{r})=(\vec{a} \cdot \vec{r}) \vec{r} \qquad \vec{a} = const.$$
$$(2) \space \operatorname{div}\vec{A}(\vec{r}) \qquad , where \thinspace \vec{A}(\vec{r})=(\vec{a} \times \vec{r})\times \vec{r} \qquad \vec{a} = const.$$
My attempt to these was to always write down the expression that would come out. I will just elaborate this for (1) but I think one gets the gist of it:
$$\nabla \cdot \vec{A}(\vec{r})= \frac{\partial}{\partial x}(a_xr_x^2+a_yr_yr_x+a_zr_zr_x)+\frac{\partial}{\partial y}(...)+\frac{\partial}{\partial z}(...)$$
As one can see this is very tedious and exhausting to do, especially during the exam, also the results are very vagues, since it depends on how the derivative of r looks like. So I am wondering, if there is a more elegant way to solve these kind of exercises.
My assumption is, that there are some neat little tricks concering the problem of having a dotproduct/crossproduct of the same vector and a constant vector. Sadly I couldn't really find anything in my lecture notes, nor on the internet.
Thanks in advance :)
P.S.: I hope this is the right place to post this question since I wasn't sure if this is rather a vector analysis or a calculus question
Mathematics news on Phys.org
Revise your equations first:
In (1). a.r is a scalar and you have a dot product between this scalar and another r.
In(2), the left-hand side is a scalar and right hand-side is a vector.
I am sorry. I corrected it.
Be happy now! Your problem is simple. At first I though you have partial differential equations.
Use the divergence formula in Cylindrical coordinate system( or Spherical depending on the definition of r). Also there are vector calculus identity for divergence of product of a vector vector and a scalar field (1) or the cross product of two vector fields (2). Find them in the following page:
https://en.wikipedia.org/wiki/Vector_calculus_identities
maxknrd said:
Compute $$(1) \space \operatorname{div}\vec{A}(\vec{r}) \qquad , where \thinspace \vec{A}(\vec{r})=(\vec{a} \cdot \vec{r})\cdot \vec{r} \qquad \vec{a} = const.$$
@maxknrd, you said you edited your post, but the first equation still doesn't make sense. As @Hassan2 already said, you can't take the dot product of a scalar and a vector.
The second dot was supposed to be a normal multiplication point. I assumed that this was a normal notation for multiplication of a scalar and a vector
This page is brilliant. The problem I have though, is that I don't know anything about r. I just know, that a is constant. The identities are a great help, but with that I would just endup writing long equations like the one I started in the original post and couldn't come to a clear solution imo
You would still need to follow some procedure to get the final expression but remember that your vector field depends on r only and in (1) it has one component only. So you only need to consider the derivation with respect to r. This makes the derivation much easier.
Likes maxknrd
Hassan2 said:
You would still need to follow some procedure to get the final expression but remember that your vector field depends on r only and in (1) it has one component only. So you only need to consider the derivation with respect to r.These makes the derivation much easier.
Okey so I will then probably have to write it down. Thank you.
I just really hoped there are some relations of taking a dotproduct/crossproduct with the vector itself
No, it isn't. The usual notation for multiplying a vector by a scalar is juxtaposition (placing the scalar next to the vector, with no intervening operator), like this:
##(\vec a \cdot \vec r) \vec r##
For a simpler example, ##c\vec v## is the scalar multiple of ##\vec v## by the scalar c.
FAQ: More elegant way to solve divergence of arbitrary dotproduct
1. What is a divergence of an arbitrary dotproduct?
The divergence of an arbitrary dotproduct refers to the result obtained when taking the dot product of two vectors that are not necessarily perpendicular to each other. It is a measure of how much the vector field is spreading or converging at a particular point.
2. Why is the divergence of an arbitrary dotproduct important?
The divergence of an arbitrary dotproduct is an important concept in vector calculus as it helps us understand the behavior of vector fields. It is also a key component in various physical and engineering applications, such as fluid dynamics and electromagnetism.
3. How is the divergence of an arbitrary dotproduct calculated?
The divergence of an arbitrary dotproduct can be calculated using the partial derivatives of the vector components in the dot product. Specifically, it is the sum of the partial derivatives of each component with respect to its corresponding variable.
4. Can the divergence of an arbitrary dotproduct be negative?
Yes, the divergence of an arbitrary dotproduct can be negative. This indicates that the vector field is converging at that particular point, meaning that the vectors are pointing towards each other.
5. Is there a more elegant way to solve the divergence of an arbitrary dotproduct?
Yes, there are various mathematical techniques and formulas that can be used to solve the divergence of an arbitrary dotproduct. Some common methods include using the product rule, the chain rule, and the identity ∇ · (fV) = f∇ · V + V · ∇f.
