More Linear Programming - help
In summary, the cargo ship has three holds for cargo. The forward hold has a capacity of 140 tons, and volume of 6,000 cubic feet; the central hold has a capacity of 800 tons, and a volume of 15,000 cubic feet; the aft hold has a capacity of 450tons and a volume of 9,000 cubic feet. Only the forward and aft holds have refrigerating systems. Assuming the papayas must be refrigerated, the linear programming model for selecting a cargo of sugar, papayas, and coconuts that maximizes profit requires solving for s, p, and c. s, p, and c represent the weight, in tons of sugar, papaya, and coconuts, respectively
flyingpig
2,579
A small cargo ship leaving Hawaii for London has three holds for cargo. The forward hold has a capacity of 140 tons, and volume of 6,000 cubic feet; the central hold has a capacity of 800 tons, and a volume of 15,000 cubic feet; the aft hold has a capacity of 450tons and a volume of 9,000 cubic feet. Only the forward and aft holds have refrigerating systems. pa Assuming the papayas must be refrigerated. Set up, but do not solve, a linear programming model for selecting a cargo of sugar, papayas, and coconuts that maximizes profit. Use the data below
[PLAIN]http://img38.imageshack.us/img38/5041/unleddmj.jpg
I don't have a clue...
call each of the cargoes s,p and c.
clearly we have s,p,c>=0
can you write an equation for the profit, something like:
P(s,p,c) = e.s+f.p+g.c
you want to maximise the profit relative to the constraints - can you write down what the constraints are?
The dimensions and capacity is killing me. They are messing me up
I need to finish this (and my other problems) by Monday (tomorrow if I sleep now)
Ask yourself: what would I need to know if I were planning the loading of the cargo? Would it be enough to know things like how many tons of papaya to put in the forward hold, etc.? If you did know all those things, could you check that the capacities were respected? Could you compute the profit?
RGV
More specifically, s, p, and c represent the weight, in tons of sugar, papaya, and coconuts, respectively.
The constraints are going to involve the amount (in tons) of each commodity, and the volume of each quantity. Note that the table gives the volume in units of cu. ft. per ton.
Here is my profit function
P = 50s + 120p + 65c
I don't know how to write the constraints!
I just tried writing my constraints
For forward hold
140 = 120s + 1200p + 600
Is that right? If so does that mean i have a lot of constraints?
For forward hold
Not quite right: you need 600c instead of 600. Also, you are computing volume, not weight, so why on Earth would you have 140? Why would you assume the hold is full? And you need a way to distinguish which hold the products are going into. So, yes: you will have a lot of variables and a lot of constraints. I get 9 variables and 9 constraints.
RGV
RGV
Was my profit function correct though?
Volume:
forward - 6000 ≥ 120s + 1200p + 600c
central - 15000 ≥ 120s + 600c (I am assuming we don't even want to put papayas in the central one?)
aft - 9000 ≥120s + 1200p + 600c
Capacity
forward - 140 ≥ 1000s + 350p + 900c
central - 800 ≥ 1000s + 900c (same argument as before, no papayas)
aft = 450 ≥ 1000s + 350p + 900c
I have 6 constraints...I am missing three
omg i forgot the constraints on how big and small can they hold! give me a minute!
Here is my new and fixed LOP
Max [tex]P = 50s + 120p + 65c[/tex]
s.t.
forward
[tex]140 \geq 350p + 1000s + 900c[/tex]
[tex]6000 \geq 1200p + 120s + 600c[/tex]
central
[tex]800 \geq 1000s + 900c[/tex]
[tex]15000 \geq 120s + 600c[/tex]
aft
[tex]450 \geq 1000s + 900c + 350p[/tex]
[tex]9000 \geq 120s + 600c + 1200p[/tex]
[tex]p \leq 0[/tex]
[tex]s \leq 0[/tex]
[tex]c \leq 0[/tex]
Again there is no p in the central hold because we don't even want any in there
Somebody please applaud me.
So, you want to ship negative amounts? That's what your p <= 0, s <= 0, c <= 0 are saying. I replaced your p<= 0, etc., by p >= 0, etc., and solved your formulation _exactly_ as you wrote it. The solution was to ship p = 0.4 tons of papaya, and no sugar or coconuts, for a total profit of $48. On the other hand, my formulation gives a very different policy and earns a profit of $12,500. So, no, I don't think applause is in order.
I can't help you any more on this question without violating the rules of this forum
RGV
nono nonononon
[tex]p \geq 0[/tex]
[tex]s \geq 0[/tex]
[tex]c \geq 0[/tex]
I was reading this all in tex and i took g for l for \leq instead of
\geq
No I just have to set up (but do not solve) the problem. However that be an bonus activity for tomorrow, but not today because I have three assignments due
flyingpig said:
nono nonononon
[tex]p \geq 0[/tex]
[tex]s \geq 0[/tex]
[tex]c \geq 0[/tex]
\geq
That's why this forum has a "preview post" button next to the "submit reply" button. You preview first, correct errors, then submit. You can preview again and again and again until you have it right.
RGV
Related to More Linear Programming - help
1. What is Linear Programming?
Linear Programming is a mathematical method used to optimize a linear objective function, subject to linear equality and inequality constraints. It is commonly used in operations research, economics, and engineering to solve real-world problems.
2. How is Linear Programming used in the real world?
Linear Programming is used to solve a variety of optimization problems, such as resource allocation, production planning, transportation scheduling, and financial planning. It is also used in business and industry to maximize profits, minimize costs, and improve efficiency.
3. What are the basic steps involved in solving a Linear Programming problem?
The basic steps in solving a Linear Programming problem include: formulating the problem, identifying the objective function and constraints, plotting the feasible region, finding the optimal solution, and interpreting the results. It may also involve sensitivity analysis and post-optimality analysis.
4. What are the limitations of Linear Programming?
Linear Programming has some limitations, such as assuming a linear relationship between variables, assuming known and constant parameters, and only being applicable to problems with a finite number of variables and constraints. It also cannot handle integer or non-linear constraints, and it may not always provide a unique solution.
5. How has Linear Programming evolved over time?
The concept of Linear Programming was first introduced in the 1930s by Leonid Kantorovich and Tjalling Koopmans. Since then, it has undergone many developments and improvements, such as the introduction of the simplex method by George Dantzig, the development of interior point methods, and the incorporation of more complex constraints and objectives. It continues to be an important tool in optimization and decision-making in various fields.
  • General Discussion
