MHB More Logic statements and arguments
  • Thread starter Thread starter ertagon2
    Logic
The discussion focuses on homework questions related to logic statements and truth tables. Q8 is confirmed correct, while Q9 part 1 requires identifying the negation of a universal statement, which translates to an existential statement. Q9 part 2 is also confirmed correct, noting the negation of a conjunction. For Q10, it is clarified that both arguments are correct if the conclusion is true whenever the premises are true. The thread concludes with a solution intended for future reference.
ertagon2
So once again this is my homework:
If you could please check these answers and help me with Q.9 part 1
Q.8 is just checking if both expressions give the same values right ?
Q.9 part 1 I'm in the blind here
Q.9 part 2 seems logical
Q.10 So if i get this right... for the statement/argument to beright the part before $\therefore$ must give me 1 when $\land$ with part after $\therefore$
This is my truth table for Q.10
https://i.imgur.com/wnthwac.jpg
Hi ertagon2,
Q8 is correct.
For Q9 part 1, the negation of a statement $\forall x : (\text{something})$ is $\exists x : \neg(\text{something})$. This means that you should have a statement equivalent to
$$\exists x\in D : \neg((x\le0)\vee(x\ge2))$$
One of the choices is indeed equivalent to that statement : do you see which one ?
Q9 part 2 is correct : the negation of $A\wedge B$ is $\neg A\vee\neg B$.
For Q10, if I'm not mistaken, both arguments are correct. The rule is that the statement after $\therefore$ (the conclusion) must be true whenever all the statements before $\therefore$ (the premises) are true. You need only check the lines in which all the premises are true; the other lines should be ignored.
castor28 said:
Hi ertagon2,
Q8 is correct.
Here's the solution for future generations.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
I'm taking a look at intuitionistic propositional logic (IPL). Basically it exclude Double Negation Elimination (DNE) from the set of axiom schemas replacing it with Ex falso quodlibet: ⊥ → p for any proposition p (including both atomic and composite propositions). In IPL, for instance, the Law of Excluded Middle (LEM) p ∨ ¬p is no longer a theorem. My question: aside from the logic formal perspective, is IPL supposed to model/address some specific "kind of world" ? Thanks.
