MHB More statistics: counting problem
The discussion focuses on calculating the number of possible telephone area codes in the U.S. and Canada based on specific digit constraints. For part 1, the total number of area codes is derived from the choices for each digit: 8 options for the first digit (2-9), 2 options for the second digit (0 or 1), and 9 options for the third digit (1-9), resulting in 144 area codes. For part 2, with the first digit fixed as 4, there is 1 choice for the first digit, while the second and third digits maintain the same options as in part 1, leading to 18 area codes starting with a 4. The application of the fundamental counting principle is confirmed to be correct for both calculations. Overall, the thread emphasizes understanding the counting principle to solve combinatorial problems effectively.
crystal1
"For years, telephone area codes in the U.S. and Canada consisted of a sequence of three digits. The first digit was an integer between 2 and 9, the second digit was either 0 or 1, and the third digit was any integer from 1 to 9.
(1) How many area codes were possible?
(2) How many area codes starting with a 4 were possible?
Again, there are no further instructions and I do not know which formula to use for this problem.
Mathematics news on Phys.org
This is an application of the fundamental counting principle, much like your previous problem.
For part 1), can you state how many choices there are for each of the digits, and then find the product of these numbers of choices?
These are my choices..
2,3,4,5,6,7,8,9
0,1
1,2,3,4,5,6,7,8,9
However, I am unsure if multiplying them all together like the last problem would work? Or if I multiply the number of choices like 8*2*9?
2,3,4,5,6,7,8,9
0,1
1,2,3,4,5,6,7,8,9
Your counts and application of the fundamental counting principle are exactly right. (Yes)
How would you now do part 2)?
6*6?
crystal said:
6*6?
For part 2), the first digit must be a 4, so we only have 1 choice there, and the remaining two digits have the same choices as they did for part 1). So, how many possible area codes do we have?
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
