Michael1160
- 16
I recently read an article where the author stated that the momentum transferred to the air by a passing wing will eventually strike the earth, even from a high cruise altitude (in other words, out of ground effect)
I have a problem with this for the following reasons, feedback would be appreciated.
There is only two ways that a fluid can impose forces on an object immersed in it:
1) Normal Forces (Pressure)
2) Tangential Forces (Friction)
From the standpoint of 2D potential flow:
Let's say we have a fluid element floating above a point on the earth. Relative to that point on the earth, the total pressure is just the static pressure of the air, made up of the density and the translational (internal) kinetic energy of the molecules.
However, approaching the fluid element from the right (the direction really does not matter) is an airplane with an airspeed of 100 Knots. Now, relative to that airplane the fluid element has a total pressure of static pressure + dynamic pressure. So, even before the airplane makes contact with the fluid element, it has effectively already done "work" on it, as the total pressure relative to the airplane has increased.
When the fluid element comes into the flow field of the wing (does not have to contact the wing, can be some distance (finite) above or below) it will go thru various velocity and "static" pressure changes. But, the mechanical energy of the flow remains constant, all accelerating and decelerating come about as a result of "internal" forces (no external forces increase or decrease the total mechanical energy- we are talking 2D potential flow).
After the wing leaves, and the fluid element exits the flow field, it will have to readjust to the freestream static pressure and direction. The fluid element will have been displaced from its initial position, downward (down wash) but it caint keep traveling in the downward direction after it leaves the flow field of the wing, as this would represent a transfer of energy to the fluid, which would mean the energy came from the airplane, which means the airplane would expierence a "drag" which 2D potential theory (D'Alembert's Paradox) says does not exist.
Now in 3D potential flow, energy will be imparted to the fluid (even without friction) as the wings will be a finite length, and the resluting wing tip vortices will repesent a transfer of energy to the fluid, which will be felt by the airplane as a drag force. These wingtip vortices distort the pressure distribution around the wing so that the pressure forces in the drag direction no longer cancel (D'Alembert's Paradox no longer valid).
Now, in real life the vortices will eventually be dissipated due to viscosity. I can see sound waves, which are weak pressure waves reaching the ground, but sound waves are not a mass movement of air.
