MHB Mortifiedpenguin1's Question from Math Help Forum
  • Thread starter Thread starter Sudharaka
    Forum
The discussion addresses how to prove that three vectors, v = (3,-1,2), b = (4,2,-5), and n = (1,3,-7), form a closed triangle by demonstrating they are non-collinear. This is established by calculating the cross product of the vectors \(\overrightarrow{vb}\) and \(\overrightarrow{vn}\), which yields a non-zero result, confirming they are not parallel. The lengths of the vectors are calculated, and using the Cosine rule, the angle between two sides is found to be approximately 119.1 degrees. This indicates that the triangle formed is an obtuse triangle. The solution effectively shows both the non-collinearity and the type of triangle formed by the vectors.
Sudharaka
MHB
Title: How do you do this problem?
Please offer step by step solutions http://mathhelpforum.com/images/smilies/smile.png
There are three vectors. They are v= (3,-1,2), b= (4,2,-5) and n= (1,3,-7). Please prove that they form a closed triangle. What type of triangle is it?
Thanks!
Hi mortifiedpenguin1, :)
I presume what you meant by a "closed triangle" is in fact to show that the given three points are non-collinear; so that a triangle is uniquely determined.
You can show that the points are not collinear by showing that the two vectors \(\overrightarrow{vb}\mbox{ and }\overrightarrow{vn}\) are not parallel. That is their cross product, \(\overrightarrow{vb}\times\overrightarrow {vn}\neq\underline{0}\)
\[\overrightarrow{vb}=\mathbf{b}-\mathbf{v}=(4,2,-5)-(3,-1,2)=(1,3,-7)\]
\[\overrightarrow {vn}=\mathbf{n}-\mathbf{v}=(1,3,-7)-(3,-1,2)=(-2,4,-9)\]
\[\Rightarrow\overrightarrow {vb}\times\overrightarrow {vn}=\begin{vmatrix} \mathbf{i} & \mathbf{j} & \mathbf{k}\\1 & 3 & -7\\-2 & 4 & -9 \end{vmatrix}=(1,23,10)\neq\underline{0}\]
Therefore the three points are not collinear, and hence they determine a unique triangle.
We shall also find the vector, \(\overrightarrow {bn}\)
\[\overrightarrow {bn}=\mathbf{n}-\mathbf{b}=(1,3,-7)-(4,2,-5)=(-3,1,-2)\]
Consider the length of the vectors, \(\overrightarrow{vb},\, \overrightarrow {vn}\mbox{ and }\overrightarrow {bn}\).
\[|\overrightarrow{vb}|=\sqrt{1^2+3^2+7^2}=\sqrt{59}\]
\[|\overrightarrow {vn}|=\sqrt{2^2+4^2+9^2}=\sqrt{101}\]
\[|\overrightarrow {bn}|=\sqrt{3^2+1^2+2^2}=\sqrt{14}\]
Let \(\theta\) be the angle between the sides, \(\mbox{vb}\) and \(\mbox{bn}\). By the Cosine rule,
\[|\overrightarrow {vn}|^2=|\overrightarrow{vb}|^2+|\overrightarrow {bn}|^2-2|\overrightarrow{vb}||\overrightarrow {bn}|\cos\theta\]
\[\Rightarrow\cos\theta=-\frac{(101-59-14)}{2\sqrt{14}\sqrt{59}}\approx -0.4871\]
\[\Rightarrow\theta\approx 119.1^{0}\]
Therefore this is an Obtuse triangle.
Kind Regards,
Sudharaka.
Mathematics news on Phys.org
b-v-n=0 Hence we have a closed triangle
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
