Moseley's law and the determination of the screening constant
In summary: Lecture%203In summary, the aim of the laboratory course was to measure the x-ray fluorescene spectra of 20 metallic samples. By comparison of the peaks in the energy spectra with known electronic transitions (e.g. ##K_α## of ##Cu##) the materials were identified. After that, Moseley's law should be verified and the screening constant ##\sigma_{n_1,n_2}## should be determined. However, the problem is that ##\sigma_{n_1,n_2}## itself is (aside from ##n_1## and ##n_2##) a function of ##Z## (the atomic number), which
Arne H
The aim of a laboratory course was to measure the x-ray fluorescene spectra of 20 metallic samples. By comparison of the peaks in the energy spectra with known electronic transitions (e.g. ##K_α## of ##Cu##) the materials were identified.
$$ \sqrt{\frac{E}{R_y}}=(Z-\sigma_{n_1,n_2})\sqrt{1/n_1^2-1/n_2^2} $$
should be verified and the screening constant ## \sigma_{n_1,n_2} ## should be determined. The problem is, that ## \sigma_{n_1,n_2}## itself is (aside from ##n_1## and ##n_2##) a function of ##Z## (the atomic number), which means it isn't possible to just fit a linear function to the data.
Moseley's law:
$$\sqrt{\frac{E}{R_y}}=(Z-\sigma_{n_1,n_2})\sqrt{1/n_1^2-1/n_2^2}$$
At first I tried to fit the data, but that does not seem to make much sense to me..
Sorry for the equations, I am new here and don't know how to properly compile LaTeX equations... :sorry:
Moderator's note: LaTex edited. See e.g. https://www.physicsforums.com/help/latexhelp/
What if you plotted ##\frac{\sqrt{\frac{E}{R_y}}}{ \sqrt{1/n_1^2-1/n_2^2} }## vs. ##Z## and fitted a straight line to that? Do you see how you can extract Moseley's constant from the fit?
Well, the curve actually shows a linear behaviour (I assume, you mean that ## \sqrt{1/n_1^2-1/n_2^2}## is constant ##\Leftrightarrow## the data has to be fitted for every transition found (## K_\alpha ##, ## K_\beta ##, ## L_\alpha ##, etc) seperately). But the problem is that ## \sigma ## seems to be also a function of ## Z ## (## \sigma < 0 ## for ## Z \geq 55## according to my course instruction)...
FAQ: Moseley's law and the determination of the screening constant
What is Moseley's law?
Moseley's law, also known as the Moseley's law of atomic numbers, states that the square root of the frequency of the characteristic x-ray emission of an element is directly proportional to its atomic number.
How is Moseley's law used to determine the screening constant?
Moseley's law can be used to determine the screening constant, which is a factor that takes into account the shielding of the nuclear charge by inner electrons. The screening constant is calculated by subtracting the square root of the frequency for a given element from the square root of the frequency for a known reference element, and then dividing by the difference in atomic numbers between the two elements.
What is the significance of the screening constant in atomic physics?
The screening constant is an important factor in atomic physics because it helps to explain the observed deviations from the expected frequencies of characteristic x-ray emissions. It also plays a crucial role in the understanding of atomic structure and the arrangement of electrons in an atom.
How was Moseley's law discovered?
Moseley's law was discovered by English physicist Henry Moseley in 1913. He conducted experiments on the characteristic x-ray emissions of various elements and found a relationship between the square root of the frequency and the atomic number. His discovery helped to fill in gaps in the periodic table and provided evidence for the existence of the atomic number as a fundamental property of elements.
Can Moseley's law be applied to all elements?
Moseley's law can be applied to most elements, specifically those with atomic numbers between 13 and 92. This is because the characteristic x-ray emissions of elements with higher atomic numbers become too difficult to measure accurately. Additionally, Moseley's law may not apply to elements with very low atomic numbers due to other factors, such as the presence of inner shell electrons.
