McKendrigo
- 26
Hi there, I'm a bit beffudled by some of the workings of a MOSFET transistor.
First of all, in the saturation region of operation, I understand that the inversion channel is "pinched off" as it approaches the drain. In other words the inversion channel thickness tapers off as it approaches the drain. Because of this, and I quote from a textbook the channel's "resistance becomes larger with increasing drain voltage, resulting in a lower rate of increase in drain current". Indeed, in a plot of drain current vs. drain voltage, the current is seen to level off.
This seems fine to me, but when I read about the channel length modulation I read that if we increase the drain voltage we shorten the length of the channel by "pinching off" more and more of it, and "Because resistance is proportional to length, shortening the channel decreases its resistance, causing an increase in current with increase in drain bias for a MOSFET operating in saturation."
This seems counter intuitive to me: if the channel has been pinched off, how can carriers readily flow between the source and drain? How can increasing the drain voltage cause the channel resistance to both decrease and increase? I can grasp that the resistance of the channel decreases simply because the resistance is proportional to how much length of channel you have...but if the channel no longer bridges between source and drain how come that doesn't mean that the resistance between source and drain is not "infinite"?
I hope my question is clear...I may be rambling a bit here ;)
