Mosfet Load switch + weird load
In summary: I said (too late at night!). Driving them outside of the rails has the same consequences in either case.
likephysics
636
I have a N-ch Mosfet load switch that connects to a WiFi module on a circuit board.
When the switch is turned OFF, I still see a voltage of 1.4V at the load.
Ckt attached.
I decreased the bleed resistor from 1k to 100 ohms. The off voltage decreased to 1.1v.
This doesn't happen with other loads like cellular modules, only with a particular WiFi module (WPER-172GN).
I don't have other wifi modules at the moment.
The N-Ch Mosfet is DMN1019
The WiFi module is WPER-172GN. The IC is Ralink RT5390. Cannot find Datasheet online!
The cellular module is EM820W and others. None of them gave me problems.
I can't figure out what kind of load would make the circuit behave like this.
  • BJT Mosfet driver.pdf
What's your voltage across the mosfet when it's Off? Is it actually 3.3? Are you sure?
I will preface this by saying I'm not an engineer I'm only a student, but as I understand it it is inadvisable to drive ground connected loads with an n channel.
Across the Mosfet, I get (3.3 - the voltage at the wifi module). If the voltage at the load is 1.4v (when switch is off), the voltage across Mosfet is 1.9v
Why is it inadvisable to drive ground connected loads with N ch?
The ckt works for every load except the wifi module.
Check the CE voltage of the 2222. You may find that you are not driving it to saturation. If this is the case then you could be using the FET in its linear region depending on the load current. This is not what you want. Try replacing the 2222 with a FET. You will need a very small gate resistance or use a logic level FET such as BSS138 where you shouldn't need a gate resistor at all. Reducing the 2222 base resistor to bring it to saturation will work as well.
Do you have any signals connected to the 3.3V module back to the 5V section? You have to be careful not to drive any signal connected to the 3.3V module outside of power supply pins. When you have the load module off it has all of it circuitry at 3.3V. If any of the pins connected to the active parts are driven to anything other than 3.3V then you are in danger of biasing the protection diodes or parasitic BJT structures. That is generally not a good idea (you can lose the magic smoke!).
BoB
Sorry i didn't get back to you. I was thinking along the same lines as rbelli above me though, that somehow you're not saturating the fet. Maybe the chip floats a small voltage for some reason? Shouldn't but you never know...
I checked the CE voltage, it's about 50-100mV. I even grounded the Mosfet gate. But I still see 1.4V at the load.
I also connected Mosfet gate directly to LAB power supply and manually varied the voltage from 0 to 5V. But no change.
BoB
I double checked this too. No signals connected. The mini PCIe connector has provision for 5V, but the corresponding pins on the module are NC. Just to eliminate any possibility of this 5V getting into module, I lifted the connector pins off the board. No use though.
Maybe you fried the FET? They can be very sensitive to static electricity. Try switching back to a module that worked in the past.
BoB
PS: Regarding off state voltage levels. They will be at 0 not 3.3 like I said (too late at night!). Driving them outside of the rails has the same consequences in either case.
BoB
The FET is working fine. No damage.
Related to Mosfet Load switch + weird load
1. What is a Mosfet Load switch?
A Mosfet Load switch is an electronic component used to turn a load (such as a motor or LED) on and off by controlling the flow of current. It is a type of transistor that acts as a switch, allowing or blocking the flow of electricity depending on the voltage applied to its gate.
2. How does a Mosfet Load switch work?
The Mosfet Load switch consists of a metal-oxide-semiconductor field-effect transistor (MOSFET) connected in a specific configuration. When a voltage is applied to the gate, it creates an electric field that controls the flow of current between the source and drain terminals. This allows the Mosfet Load switch to turn the load on or off.
3. What makes a Mosfet Load switch different from other types of switches?
Unlike traditional mechanical switches, a Mosfet Load switch does not have any moving parts, making it more reliable and durable. It also has a low on-resistance, meaning it can handle higher currents with minimal power loss. Additionally, it can be controlled by a small voltage, making it suitable for use in electronic devices.
4. What is meant by "weird load" in the context of Mosfet Load switch?
The term "weird load" refers to a load that has unusual characteristics, such as a non-linear voltage-current relationship or a highly variable current draw. These types of loads can be challenging to control with traditional switches, but a Mosfet Load switch can provide more precise and efficient control.
5. What are some common applications of Mosfet Load switches?
Mosfet Load switches are commonly used in electronic devices to control the flow of current to various components, such as LEDs, motors, and sensors. They are also used in power management circuits to regulate the power supply to different modules and protect against overcurrent conditions. Additionally, they can be found in battery-powered devices to conserve power by turning off the load when not in use.
  • Electrical Engineering
