Most general multiplicative sequence is ?
In summary, the conversation discusses the form of a sequence of complex terms, given the relation a_{nm}=a_{n}a_{m}, for all n,m in the natural numbers. The speaker asks for the most general form of this sequence, which is shown to be a_{\prod p_{k}^{\alpha_{k}}}= \prod a_{p_{k}}^{\alpha_{k}} where p_{k} are primes and \alpha_{k} are integers. The speaker also mentions that the sequence a_{k}=k^{b} is a possible form and asks for other qualifying sequences. The possibility of a_{2n}=a_{2}a_{n} is also brought up, and
benorin
Insights Author
1,443
191
If [tex]a_{nm}=a_{n}a_{m}, \, \forall n,m\in\mathhbb{N} ,[/tex] then the sequence of complex terms [tex]a_{nm}[/tex] is (generally) of what form? That is, I would like to know what the most general sequence satisfying the above relation is. For example, it is clear that we must have [tex]a_{1}=1[/tex] and that for primes [tex]p_{k}[/tex] and integers [tex]\alpha_{k}[/tex] we have
[tex]a_{\prod p_{k}^{\alpha_{k}}} =\prod a_{p_{k}}^{\alpha_{k}} [/tex]
and, clearly, for any constant b, the sequence [tex]a_{k}=k^{b}[/tex] is such a sequence, what other types of sequences qualify? would the lesser requirement that [tex]a_{2n}=a_{2}a_{n}, \, \forall n\in\mathhbb{N} ,[/tex] give any more possibilities?
Surely you can give a complete classification of all possible sequences (what, again, constitutes 'generality' and how are you quantifying it?) since any such sequence is uniquely determined by its value at the prime indics, and any assignment of values to prime indices gives a sequence.
I just want an idea of what the typical families of sequences of this sort are.
And I told you what every single sequence of this type is. They are called completely multiplicative functions.
FAQ: Most general multiplicative sequence is ?
What is a multiplicative sequence?
A multiplicative sequence is a sequence of numbers where each term is obtained by multiplying the previous term by a fixed number. For example, the sequence 2, 4, 8, 16, 32 is a multiplicative sequence where each term is obtained by multiplying the previous term by 2.
What is the most general multiplicative sequence?
The most general multiplicative sequence is a sequence where the fixed number used to obtain each term can be any real number, not just an integer. This means that the sequence can have decimal or fractional terms.
How is a multiplicative sequence different from an arithmetic sequence?
A multiplicative sequence is different from an arithmetic sequence in that the terms are obtained by multiplying the previous term by a fixed number, while in an arithmetic sequence, the terms are obtained by adding a fixed number to the previous term.
Can a multiplicative sequence have negative terms?
Yes, a multiplicative sequence can have negative terms. This can happen if the fixed number used to obtain each term is a negative number.
Are there any practical applications of multiplicative sequences?
Yes, multiplicative sequences have practical applications in fields such as finance, chemistry, and biology. For example, compound interest in finance follows a multiplicative sequence, and in chemistry, the rate of reaction can be modeled using a multiplicative sequence.
