Most Generalized Lensmaker's Equation
  • Thread starter TaylorRiles
  • Tags
    generalized
In summary: For spherical interfaces, the paraxial refraction formula works:n1/t1 + n2/t2 = (n2-n1)/Rwhere n1 is the index of the first medium and n2 is the index of the second medium. t1 and t2 are the distances from the center of the sphere to the two interfaces respectively, and R is the radius of curvature of the sphere. In summary, the problem involves a glass sphere with a radius of 10 cm and an index of refraction of 1.52, coated with a reflecting layer over one hemisphere. An object with a height of 1 cm is placed 15 cm in front of the clear surface of the sphere. To determine the position
TaylorRiles
Problem Statement: A glass sphere with radius R = 10 cm and index n = 1.52 is coated with a reflecting layer over one hemisphere. An object with a height of h = 1 cm is placed within 15 cm in front of the clear surface of the sphere. Determine the position, the size, and the character of the final image.
My issue is that there are too many generalizations to account for, and I can't find the right equations. We cannot use the thin lens equation because the lens is a sphere; I don't think we can use the ordinary mirror formula because the reflective surface is inside a medium with non-unity index of refraction. And how does object height fit into all this?
Lensmaker's formula that accounts for thick lenses:
1/f = (n - 1)(1/R1 - 1/R2 + ((n-1)d)/(n*R1*R2)
where n is index of refraction of lens, d is thickness of lens (in this case diameter of sphere, I believe), R1 is radius of lens facing object, R2 is radius facing away (will be negative).
Lensmaker's formula that accounts for objects in different media:
1/f = [ (n of lens/n of outside medium) -1][ (R1-R2)/R1*R2]
Mirror formula (whose assumptions may or may not include immersion in not-air medium)
1/p + 1/q = -2/r
where r is radius of curvature, p is object distance, q is image distance.
First considered lens. Used lensmaker's formula for thick lenses and used the formula
1/f = (n lens) - 1)(1/R1 - 1/R2 + ((n-1)d)/(n*R1*R2), with R1 = 10,R2 = -10, n = 1.52, d = 20. Got f of lens equal to -7.16. The solutions manual says that's incorrect, and they use this formula:
1/(object distance) + (n lens)/(image distance) = ((n lens)-1)/R.
I can see where the right side came from, but not the n lens on top of image distance. Help?
And then once the mirror comes in, I'm lost. The image should form way to the right of the mirror but never does. How do we deal with that?
Thanks so much!
Welcome to PF;
The most general formulation of par-axial ray optics is probably the ray-transfer matrix formulation.
It will even handle mirrors.
I know it is convenient to just plug numbers into equations and believe whatever comes out but that is not how physics is done.
You are best letting the physics be your guide and running through the calculation in several steps.
The fat-lense lensmakers equation is not appropriate fr this situation because you don't have a fat lens.
In the par-axial approximation, what you have is a 3-element system ...
1. spherical interface
2. length of glass
3. spherical mirror
Related to Most Generalized Lensmaker's Equation
What is the Most Generalized Lensmaker's Equation?
The Most Generalized Lensmaker's Equation is an equation used in optics to determine the focal length and power of a lens based on its physical properties, such as curvature and refractive index.
What are the variables in the Most Generalized Lensmaker's Equation?
The variables in the Most Generalized Lensmaker's Equation include the refractive indices of the two media surrounding the lens, the radii of curvature for the two lens surfaces, and the thickness of the lens.
How is the Most Generalized Lensmaker's Equation derived?
The Most Generalized Lensmaker's Equation is derived from the combination of the thin lens equation and Snell's law, which govern the behavior of light passing through a lens.
What are the applications of the Most Generalized Lensmaker's Equation?
The Most Generalized Lensmaker's Equation is used in the design and manufacturing of lenses for various optical instruments, such as cameras, telescopes, and microscopes.
What are the limitations of the Most Generalized Lensmaker's Equation?
The Most Generalized Lensmaker's Equation assumes that the lens is thin, has a small aperture, and is made of a homogeneous material, which may not always be the case in real-world scenarios. It also does not take into account the effects of aberrations on the lens performance.
