Motion and Force - Some questions after doing revision.
In summary: Overall, the combination of these forces causes the car to slow down when the brakes are applied.In summary, the conversation discusses various physics concepts, including calculating acceleration and friction, the falling rate of objects in liquid, the effect of cycling position on top speed, the difference in top speed on different road conditions, and the definition and explanation of braking distance in vehicles.
yutou.eu
I am having assessment test for this chapter tomorrow, I have some questions after doing this whole chapter questions. Hope you guys can help me :)
1. A brick of mass 3.2Kg on a sloping flat roof, at 30 degree to the horizontal, slides at constant acceleration 2.0m down the roof in 2.0 s from rest Calculate:
a. the acceleration of the brick.
> hmm. a = (v-u)/t..? F = ma so a = F/m..? or mgsin(delta) - F0 = ma?
b. the frictional force on the brick due to the roof.
friction force mean the force is pulling upward isn't it? so is it the same F=ma?
2. Wheather or not a smaller steel ball would fall at the same rate in the same liquid?
Edited: I have found that will be the same rate no matter how heavy the object is, but is it the same in the liquid?
3. Why a cyclist can reach a higher top speed by crouching over the handlebars instead of sitting upright while pedalling?
4. Why a vehicle has a higher top speed on a downhill stretch of road than on a level road?
5. What is meant by the bracking distance of a vehicle?
>Braking distance refers to the distance a vehicle will travel from the point where its brakes are fully applied to when it comes to a complete stop. From Wikipedia.
6. Explain in terms of the forces acting on the wheels of a car, why a vehicle slows down when the brakes are applied.
>The brakes produce a force that acts in the opposite direction of the motion of the vehicle, reducing its speed. This force is known as the braking force, and it acts on the wheels of the car, causing them to turn more slowly. The friction between the tires and the road also helps to slow down the car by providing an opposing force to the movement of the wheels.
Related to Motion and Force - Some questions after doing revision.
1. What is the difference between motion and force?
Motion refers to the change in position or location of an object over time, while force is a push or pull on an object that causes it to move, accelerate, or change direction.
2. How are motion and force related?
Force is necessary for motion to occur. Without a force acting on an object, it will remain at rest or continue moving at a constant speed and direction.
3. What is Newton's first law of motion?
Newton's first law of motion, also known as the law of inertia, states that an object will remain at rest or in motion at a constant velocity unless acted upon by an external force.
4. How do you calculate force?
Force can be calculated using the equation F=ma, where F is force, m is mass, and a is acceleration. The unit of force is Newtons (N).
5. What is the difference between mass and weight?
Mass is a measure of the amount of matter in an object, while weight is a measure of the force of gravity on an object. Mass is measured in kilograms (kg) and weight is measured in Newtons (N).
