Motion, Energy balance, momentum question
In summary, the conversation discussed a problem involving a block of mass 10kg on a table and a bullet of mass 50g embedding into the block. Using momentum and energy conservation, it was determined that the block would end up moving at a speed of approximately 200√2 m/s. The conversation also mentioned a problem with a freely falling object acquiring a speed v/10 after being dropped from a height H, and using the equation mgH = 1/2 m (v/10)^2, it was determined that H is equal to 0.04 km. However, it was noted that this value does not match any of the given options, indicating an error in the problem.
Raghav Gupta
1,011
76
A block of mass m= 10kg rests on a horizontal table. The coefficient of friction between the block and the table is 0.05.
When hit by a bullet of mass 50 g moving with speed v, that gets embedded in it, the block moves and comes to stop after moving a distance of 2m on the table.
If a freely falling object were to acquire speed v/10 after being dropped from height H, then neglecting energy losses and taking g= 10 m/s2, the value of H is close to:
A. 0.2 km
B. 0.3 km
C. 0.4 km
D 0.5. km
Momentum conservation, energy conservation, Newton laws
$$M_{bullet} v = ( m_{block} + M_{bullet} )v_{block} $$ ( momentum conservation)
$$ 1/2 (m_{block} + M_{bullet}) v_{block}^2 = μ (m_{block} + M_{bullet}) g s$$ energy conservation
$$ v_{block}^2 = 2μgs = 2 * 0.05 * 10 * 2 = 2 $$
$$ v_{block} = √2 m/s $$
$$ v = ( m_{block} + M_{bullet} )v_{block}/M_{bullet} ≈ 10000 * √2/50 = 200√2 m/s $$
$$ v/10 = 20√2 $$
Now, ## mgH = 1/2 m (v/10)^2 ##
## ⇒ H = (20√2)^2/2g = 800/20 = 40 m = 0.04 km ##
What wrong I have done here?
It is not matching with options.
What options are there?
I think you rounded off too early.
0.4 km
0.3 km
0.2 km
0.5 km
But why so error in rounding?
By a factor of 10?
It is not rounding error. Your result is correct, the problem maker has error.
Likes Raghav Gupta
Related to Motion, Energy balance, momentum question
1. What is motion?
Motion is the change in position of an object over time. It can be described in terms of displacement, velocity, and acceleration.
2. What is energy balance?
Energy balance refers to the relationship between the energy intake and energy expenditure of an object or system. If the energy intake is greater than the energy expenditure, the system will have a positive energy balance and vice versa.
3. How is momentum calculated?
Momentum is calculated by multiplying an object's mass by its velocity. The formula is p = mv, where p is momentum, m is mass, and v is velocity.
4. What is the law of conservation of energy?
The law of conservation of energy states that energy cannot be created or destroyed, only transformed from one form to another. This means that the total amount of energy in a closed system remains constant.
5. How is energy related to motion?
Energy and motion are closely related. An object in motion has kinetic energy, which is the energy of motion. Additionally, the amount of energy that an object has affects its motion, as seen in the law of conservation of energy.
