Motion in 2 dimension-example from book
In summary: In this problem, the x-component of the velocity vector of the plane is the horizontal velocity of the plane.In summary, the plane should fly North at a y-component of 1290kmh^-1 and a x-component of 190kmh^-1, meaning it needs to fly slightly into the wind. The equation is set to zero to ensure that the plane does not drift to the west or east.
negation
818
A jetliner flies at 960kmh^-1 relative to the air. it's going from Houston to Omaha, 1290km Northwards. At cruising altitude a wind is blowing east wards at 190kmh^-1. In what direction should the plane fly? How long will the trip take?
None
This is the part I am unclear:
x-component: v' cos Θ + V = 0
y-Component: v' sin Θ + 0 = v
I can understand why V is added to v' cos Θ: both are in the same x-direction.
I don't understand the reason behind the y-component.
Also, what is the reason for setting the equation to be zero?
V would need to be negative for the first term to work. I think that's saying you need to fly a bit into the wind to go in a straight line. (i.e. in the opposite direction to the wind).
If you have a vector, v', that's not parallel to either the x or y axis, then it has a component in both the x and y directions. The sin and cos decompose the magnitude of that vector into its x contribution and y contribution. The plane wants to fly North, so it should have a positive y value, but the x value should be zero, so you enforce this condition. You don't want the plane drifting to the west or east.
As regards the x-component, the question I were to ask myself would be "given the gust blowing east wards (horizontal) at 190kmh^-1, at what horizontal velocity must the plane be flying such that x=0kmh^-1", am I right?
If by x you mean the x-component of the overall velocity vector of the plane, then yes. I clarify this because often x is the position, and something like v_x would be horizontal velocity.
FAQ: Motion in 2 dimension-example from book
What is motion in 2 dimensions and how is it different from motion in 1 dimension?
Motion in 2 dimensions refers to the movement of an object in two perpendicular directions, such as up and down and left and right. This is different from motion in 1 dimension, which only involves movement along a single axis.
What is an example of motion in 2 dimensions?
An example of motion in 2 dimensions is a ball rolling off a table. The ball will move both horizontally and vertically as it falls to the ground.
How is motion in 2 dimensions described mathematically?
Motion in 2 dimensions is described using vectors, which have both magnitude and direction. The displacement, velocity, and acceleration of an object in 2 dimensions can be represented using vectors.
What is the difference between displacement and distance in motion in 2 dimensions?
Displacement refers to the shortest distance between the starting point and ending point of an object's motion, while distance is the total amount of ground covered by the object. In motion in 2 dimensions, displacement takes into account both horizontal and vertical displacement, while distance only considers the total distance traveled.
How does projectile motion illustrate motion in 2 dimensions?
Projectile motion is a classic example of motion in 2 dimensions. It involves the motion of an object that is launched into the air and moves along a curved path under the influence of gravity. The horizontal and vertical components of the object's motion make it a perfect example of motion in 2 dimensions.
