Motion in one dimension, Kinematics equations
In summary: Acceleration should be the same as spacecraft 1, -15.5 m/s^2.In summary, the problem involves two spacecraft that need to dock by arriving at the same position with zero velocity. The first spacecraft has an initial velocity of 525 m/s and a constant acceleration of -15.5 m/s^2. Using the equations Vf = Vi + at and d = 1/2(Vi + Vf)t, it was determined that the second spacecraft should have the same time and acceleration as the first, and an initial velocity of 9,217 m/s to reach the same position.
chuckbalzer
Two spacecraft are 13,500m apart and moving directly toward each other. The first spacecraft has in initial velocity of 525 m/s and accelerates at a constant -15.5 m/s^2.
They want to dock, which means they have to arrive at the same position at the same time with zero velocity. (a) What should the initial velocity of the second be? (b) What should be it's constant acceleration?
SC1 Vi = 525 m/s
SC1 Vf = 0.0 m/s
SC1 a = -15.5 m/s^2
SC1 d = 8891.129032 m
SC1 t = 33.870967
SC2 Vi = unknown
SC2 Vf = 0.0 m/s
SC2 a = unknown
SC2 d = 4608.870968
SC2 t = I think it would be the same time as SC1?
Vf = Vi + at
d = Vit + 1/2at^2
Vf^2 = Vi^2 + 2ad
d = 1/2(Vi + Vf)t
I used (Vf^2 = Vi^2 + 2ad) and solved for d to find out the distance SC1 would travel until it's velocity reached 0 m/s
I then subtracted that from 13,500 to find d for SC2.
I used (Vf = Vi + at) to find t for SC1
Because the problem says they need to be there at the same time I thought I would use the time for SC1 for SC2 but using (d = 1/2(Vi + Vf)t) and solving for Vi gave me 9,217 m/s... sounds bogus to me.
I know I need Two equations for Two unknown variables and solve them as one equation but I just don't know how to get there and put them together. This is my first physics class and I just need an example of what I need to do to get going. I tried every possible combination I could think of and I've realized that I clearly am misunderstanding something.
Thanks in advance for any and all help
-Chuck
Your time for spacecraft 2 should be the same, then you could use d=1/2(Vi+Vf)t to solve for the initial velocity.
Related to Motion in one dimension, Kinematics equations
What is motion in one dimension?
Motion in one dimension refers to the movement of an object along a straight line. It only considers the object's position, velocity, and acceleration in one direction.
What are the kinematics equations?
Kinematics equations are mathematical formulas that describe the relationship between an object's position, velocity, and acceleration in one-dimensional motion. They include equations such as position-time, velocity-time, and acceleration-time equations.
What is displacement?
Displacement is the change in an object's position from its initial point to its final point. It is a vector quantity and is represented by the symbol Δx.
What is velocity?
Velocity is the rate of change of an object's displacement. It is a vector quantity and is represented by the symbol v. The SI unit for velocity is meters per second (m/s).
What is acceleration?
Acceleration is the rate of change of an object's velocity. It is a vector quantity and is represented by the symbol a. The SI unit for acceleration is meters per second squared (m/s^2).
