Motion in one dimension- total trip time
In summary, the person takes a trip, driving with a constant speed of 94.0 km/h except for a 22.0-min rest stop. The person's average speed is 71.5 km/h.
QuantumCurt
Education Advisor
726
166
A person takes a trip, driving with a constant speed of 94.0 km/h except for a 22.0-min rest stop. The person's average speed is 71.5 km/h.
(a) How much time is spent on the trip?
(b) How far does the person travel?
This is for introductory general physics. We just finished the first chapter on motion in one dimension. We derived the kinematics equations today, but I can't seem to apply one of the standard kinematics to this. I don't know what I'm missing here.
I let the total displacement equal
[tex]\Delta{x}=v_{1}t_{1} \ \ \ \ \ v_{1}=94.0km/hr[/tex]
[tex]\Delta{t}=t_{1}+t_{2} \ \ \ \ \ t_{2}=22.0min \ \ \ rest \ stop[/tex]
[tex]\Delta{x}=v_{2}(t_{1}+t_{2}) \ \ \ \ v_{2}=71.5km/hr \ \ average \ speed[/tex]
Then I set the two [itex]\Delta{x}[/itex] values equal to each other.
[tex]v_{1}t_{1}=v_{2}(t_{1}+t_{2})[/tex]
Now I need to solve for [itex]t_{1}[/itex], but I can't find a way of doing so that will work. I feel like I'm making this a lot more complicated than it needs to be. Anyone have any suggestions?
Your work looks good. Try using the distributive law of multiplication to write the right hand side of your equation as ##v_{2}t_{1}+v_{2}t_{2}##.
I tried that before, and I seemed to hit a dead end.
[tex]t_{1}=\frac{v_{2}t_{1}+v_{2}t_{2}}{v_{1}}[/tex]
Now I need to eliminate the [itex]t_{1}[/itex] that's still on the right hand side, correct? I can't see any way of doing that without losing the [itex]t_{1}[/itex] on the left hand side. I could multiply the whole thing by the reciprocal of the [itex]t_{1}[/itex], but that would cancel it on the left hand side, and then I'd still have it in the denominator in the right hand side, which would lead me back to exactly where I'm at now.
Perhaps a slightly different approach to the equations will help. If you let T be the total time for the trip, and R the time spent resting, then can you write two equations for the total distance traveled, one using the driving speed and one using the average speed?
I suggest a different approach to the equations like gneill, too. But the only thing to consider is what really is the value of the average speed. I say this because it is very important not losing sight of the goal when you handle the equations.
If you want to stick with your original approach, you have ##v_1t_1 = v_2t_1+v_2t_2##
You already know the value of ##t_2##. So, as you say, you only need to find ##t_1##. You have two terms in the equation with ##t_1##. Can you get those two terms on the same side of the equation?
It's going to be like solving ##5x = 2x + 6##.
Of course, you can take a different approach like gneill and LeonhardEu suggest if you want. But I think you're already close to the answer.
Can I treat the [itex]v_{2}[/itex] and [itex]v_{1}[/itex] as being coefficients, like this?
[tex]v_{1}t_{1}=v_{2}t_{1}+v_{2}t_{2}[/tex]
Then subtract the [itex]v_{2}t_{1}[/itex]
[tex](v_{1}-v_{2})t_{1}=v_{2}t_{2}[/tex]
Then divide to get-
[tex]t_{1}=\frac{v_{2}t_{2}}{v_{1}-v_{2}}[/tex]
Then solve to get-
[tex]t_{1}=\frac{(71.5 \ km/hr)(22.0 \ min)(\frac{1 \ hr}{60 \ min})}{(94.0 \ km/hr-71.5 \ km/hr)}[/tex]
To get 1.17 hours total time spent on the trip?
edit-No, that wouldn't be total time. I'd need to add the 22.0 min at the rest stop for total time, right? That would give me a total time of 1.54 hours.
Yes. That's right. Good work.
Awesome, thanks for the help! I didn't think of the fact that I could basically treat the velocities as being coefficients of the time. That seems a lot more clear now.
Related to Motion in one dimension- total trip time
What is motion in one dimension?
Motion in one dimension refers to the movement of an object along a single straight line. It is also known as linear motion.
What is total trip time?
Total trip time is the amount of time it takes for an object to travel from its initial position to its final position. It is the sum of the time taken for each individual segment of the trip.
How is total trip time calculated?
Total trip time can be calculated by dividing the total distance traveled by the average speed of the object. It can also be calculated by adding the time taken for each segment of the trip.
What factors affect total trip time?
The total trip time is affected by the distance traveled, the speed of the object, and any changes in speed or direction during the trip. Other factors such as air resistance and friction may also affect the total trip time.
How is total trip time different from average speed?
Total trip time accounts for the entire duration of the trip, while average speed only considers the overall speed of the object. Total trip time also takes into account any changes in speed or direction, while average speed does not.
