Motion in One Dimension (Using Calculus)
In summary: When you make the acceleration function a(t) = 0, that yields a value of time. It's units are in seconds are they not? Not units of acceleration - m/s^2?Isn't that then the time you are looking for with which to solve for the other values?Yes, I see what you're saying. The number is right, but yes, the units should be in seconds.
jmartella
The speed of a bullet as it travels down the barrel of a rifle toward the opening is given by v = (-5.95 multiplied by 107) t 2 + (2.45 multiplied by 105) t, where v is in meters per second and t is in seconds. The acceleration of the bullet just as it leaves the barrel is zero.
(b) Determine the length of time the bullet is accelerated.
(c) Find the speed at which the bullet leaves the barrel.
(d) What is the length of the barrel?
Taking the derivative of the given equation, I got the function for acceleration, and integrating the given function, I got the position function.
a(t)=-1.19*10^8t+2.45*10^5
x(t)=-1.98*10^7t^3+1.23*10^5t^2
(b)Using the acceleration formula I derived, I plugged in 0 because the given info says that the acceleration of the bullet just as it leaves the barrel is 0, and got an answer of .002m/s^2. The Webassign is telling me that the answer is within 10% of the correct answer, but I'm stuck.
(c&d) I don't even think there is enough information to solve for either of these.
Welcome to PF.
Just to be sure I have it right:
[tex]v = 2.45 * 10^5 * t - 5.95 * 10^7 * t^2[/tex]
Oh, sorry, I forgot to adjust it in the given information.
v(t) = -5.95*10^7*t^2 + 2.45*10^5*t
When you set a(t) = 0, you get the time that a is 0.
Your answer is .002 m/s^2 ?
Using significant digits digits more formally, rather than the .002 you submitted, I would suggest a more precise 2.06 x 10^-3 to be consistent with the form of your givens.
I didn't put 0 in as the value for t, I made the function equal to 0, because I believe that the problem stated that the acceleration of the bullet was 0, but I'm not exactly sure. Actually, reading over the problem again, it's asking for the amount of time that the bullet was accelerated, so I guess it had to be at one point, obviously.
I just don't see how there is enough information to solve for the answers it wants.
I also tried putting the value as 2.06 x 10^-3 and was also wrong.
I understand. But when you make the acceleration function a(t) = 0, that yields a value of time. It's units are in seconds are they not? Not units of acceleration - m/s^2?
Oh, okay. Yes, I see what you're saying. The number is right, but yes, the units should be in seconds. I talked it over with a friend of mine who took AP Physics last year, and he agreed with me that the time that was yielded from setting a(t)=0 is the amount of time the bullet was in the barrel, which is also the amount of time it was accelerated, but for some reason, the answer isn't being accepted. Any other ideas? =/
From the statement that I have of the problem and reviewing your integral and derivative that's the time I would use to solve for V and the x from 0, i.e. the barrel length.
Is there a part (a) to the question?
Alright, I retried doing the problem. For part (b), instead of putting .0021, I put .00206, and it gave me credit for the problem. Using that time value instead of the first one, all the rest of the answers were correct. Thanks for you help though, I hope you didn't get as frustrated as I did.
No frustration at all for me. Glad to see it resolved. Congrats to you for staying after it.
FAQ: Motion in One Dimension (Using Calculus)
What is the difference between position, velocity, and acceleration?
Position is the location of an object in space, velocity is the rate of change of an object's position, and acceleration is the rate of change of an object's velocity.
How is motion in one dimension represented mathematically?
Motion in one dimension can be represented using a position-time graph, a velocity-time graph, or an acceleration-time graph. These graphs show the relationship between an object's position, velocity, or acceleration and time.
What is the role of calculus in studying motion in one dimension?
Calculus is used to find the instantaneous rate of change of an object's position, velocity, or acceleration at any given point in time. It allows for a more precise analysis of an object's motion compared to using average rates of change.
How do you determine the displacement of an object using calculus?
The displacement of an object can be determined by finding the area under the velocity-time graph using calculus. The definite integral of the velocity function with respect to time will give the displacement of the object.
What are some real-life applications of using calculus to study motion in one dimension?
Calculus is used in many real-life applications, such as designing roller coasters, analyzing the motion of planets and satellites, and creating accurate weather predictions. It is also used in the fields of engineering, physics, and astronomy to study and understand the motion of objects in one dimension.
