Motion in Space: Velocity and Acceleration
In summary, for the given function V(t) = (1+t)i + (t^2-2t)j, the velocity is v'(t) = <1,2t-2> = <1, 2(t-1)>, the acceleration is a(t) = <0,2>, the speed/length is given by the square root of (1+4(t-1)^2), the unit tangent is <1,2(t-1)> / square root (1+4(t-1)^2), and to find the tangential and normal components, one can use the formulas: \vec{a}_{||} = \frac{\vec{a} \cdot \vec{b
Physicsnoob90
51
For V(t) = (1+t)i + (t^2-2t)j find:
1. velocity
2.Acceleration
3. speed/length
4. Unit Tangent
5. tangential component
6. normal component at t=2
1. v'(t) = <1,2t-2> = <1, 2(t-1)>
2. a(t) = <0,2>
3. length = Square root of (1+4(t-1)^2)
4. Unit Tangent = <1,2(t-1)> / square root (1+4(t-1)^2)
from here I'm stuck trying to find the tangential component and normal component. [/B]
1. velocity
2.Acceleration
3. speed/length
4. Unit Tangent
2. a(t) = <0,2>
First decide: normal and tangential component of WHAT? In general, if you have two vectors ##\vec{a}, \vec{b}## the component ##\vec{a}_{||}## of ##\vec{a}## parallel to ##\vec{b}## and the component ##\vec{a}_{\perp}## perpendicular to ##\vec{b}## are
[tex] \vec{a}_{||} = \frac{\vec{a} \cdot \vec{b}}{\vec{b} \cdot \vec{b}} \vec{b} \\
\vec{a}_{\perp} = \vec{a} - \frac{\vec{a} \cdot \vec{b}}{\vec{b} \cdot \vec{b}} \vec{b}[/tex]
Related to Motion in Space: Velocity and Acceleration
1. What is velocity and how is it related to motion in space?
Velocity is a measurement of the rate and direction of an object's motion in space. It is typically expressed in units of distance per time, such as meters per second. Velocity is related to motion in space because it describes how fast an object is moving and in which direction it is moving.
2. How is acceleration defined in the context of motion in space?
Acceleration is the rate at which an object's velocity changes over time. It can be caused by a change in speed or direction of motion. In space, objects experience acceleration due to the force of gravity and other celestial forces.
3. What is the difference between uniform motion and accelerated motion?
Uniform motion refers to a constant velocity, meaning an object is moving at a consistent speed and in a straight line. Accelerated motion, on the other hand, is when an object's velocity is changing, either by speeding up or slowing down, or by changing direction.
4. How is the motion of objects in space affected by gravitational force?
Objects in space are affected by gravitational force, which is the attractive force between two objects with mass. This force causes objects to accelerate towards each other. In the context of motion, gravitational force can cause an object to change its direction or speed, depending on the mass and distance of the objects involved.
5. How do scientists measure the velocity and acceleration of objects in space?
Scientists use various instruments and techniques to measure the velocity and acceleration of objects in space. These may include radar, telescopes, and satellites. By tracking an object's position over time, scientists can calculate its velocity and acceleration using mathematical formulas.
