Motion in straight line in bungee jumping
In summary, bungee jumping involves a free fall motion followed by a series of oscillations as the jumper is connected to an elastic cord. Initially, the jumper accelerates downward due to gravity, reaching terminal velocity before the cord begins to stretch. The elasticity of the cord then converts kinetic energy into potential energy, causing the jumper to rebound upward. The cycle of falling and rebounding continues until energy is dissipated, leading to a gradual halt. Understanding the physics of motion in a straight line is crucial in analyzing the forces and energy transformations involved in bungee jumping.
Kevin98
Dito will do bungee jumping. He will jump from a height of 47 meters above the water surface. When he jumps, he will be thrown back when the rope shortens and will oscillate up and down. Dito's speed when he fell was 70 km/hour with a slope level of almost 180⁰. How long does it take for the dito to touch the surface of the water?
vf = vi + at
vf² = vi² + 2as
vf²= vi² +2as
vf² = (19,44)² + 2(9,81)(47)
vf = 36,05 m/s
to find the t, we can use formula:
t = (vf - vi)/a
t = (36,05 - 19,44)/9,81
t = 1,693 s.
Is it correct?
You might want to show the working for the conversion from km/h to m/s.
70 km/h = (70.000 m/3600 s) = 19,44 m/s
Kevin98 said:
t = 1,693 s.
Is it correct?
Just a few comments in addition to @pasmith's...
Are you sure the question is correctly stated? How can Dito realistically have an initial velcoity of 70km/h downwards? That's fast.
Check the number of significant figures in your final answer.
It may be worth stating the sign-convention you are using (what direction is positive).
An alternative method is to use ##s =v_i t + \frac 12 at^2## - but that means you have to solve a quadratic equation. If you don't want to do that, you can still use the equation to check that your answer gives the correct distance for the time you have calculated.
Likes MatinSAR
Yep. 70 km/h. I also think that it is too fast, but that is what the question says.
In post #4 I should also have said that you are assuming the acceleration is a constant 9.81m/s² downwards. You have calculated the time taken for an object to free-fall 47m.
But there is a bungee-rope - so the acceleration will not be 9.81m/s² downwards all the time.
It sounds like there is a problem with the question. I'd recommend checking.
Is it possible that what the question means by "Dito's speed was 70 km/h when he fell" is the speed when he hit the water surface and the initial speed was zero? If we go by this assumption, the acceleration is definitely not 9,81 m/s². I think you're right and there is a problem with the question itself. I found this question in a chapter about motion kinematics. So, I assume there won't be analysis about different forces acting on an object. What do you think? I also find another problematic question and solution in this book, which I will post later.
Since this is a kinematics problem, I think the interpretation could be the ## 70 ~\rm{km/hr}## was the jumpers maximum speed (just before the bungee engages). Then perhaps they accelerate to rest in the remaining distance at a constant rate.
Likes hmmm27
If so, I hope Dito sued whoever organised the jump!
I would guess that the intended question is:
a) initial speed = 0;
b) 70 km/h is the maximum speed reached;
c) the bungee rope then causes deceleration;
d) the speed reaches 0 after a total distance of 47m has been covered.
The problem is then what value to use for deceleration. But, as you say, this is then no longer a kinematics equation. [EDIT - but see Post #10.]
If there is an 'official answer' (even if only a single value) given, it would be interesting to know what it is. It might then be possible to work backwards to find the intended question.
I agree. [EDIT - but see Post #10.]
Yippee.
Edit - minor corrections.
Likes MatinSAR and Lnewqban
Note that, if the rope obeys Hooke's law, the motion when the rope is in tension is simple harmonic. If you have studied simple harmonic motion (SHM) it gives you a way to proceed without considering forces and mass (assuming 70 km/h is Dito's max speed).
This problem statement is incomplete. We are told that the distance to the water is 47 m. That's fine. We are also told that "When he jumps, he will be thrown back when the rope shortens ##\dots## My questions are (a) At what distance from the water does the rope shorten? (b) How stiff is the rope (spring constant)?
Likes MatinSAR
If the origin is at the point where the bungee engages, then:
$$ x(t) = \frac{v_o}{\omega} \sin ( \omega t ) $$
Seems like there are more variables than equations for that, but maybe I'm missing something?
I think this is OK...
The speed ##v_{max}## = 70km/h when the bungee engages (say extension ##x=0##).
The speed is zero at the water surface; so the amplitude of SHM is ##A =## [distsance between the point where ##x=0## and water surface]
##v_{max} = 2 \pi f A## (a standard equation in SHM)
One quarter of a full cycle is performed between the point where x=0 and the first encounter with the water surface.
Or maybe I've said too much.
EDIT: I certainly have said too much! What I said is wrong - see later Posts.
Likes MatinSAR
Ok, the other equation is the velocity. Thanks!
Does it go like this?
Dito's initial speed vi1 = 0
Dito's max speed vi2 = 70 km/h = 19,44 m/s (before the bungee engages, acceleration = 9,81 m/s²)
The initial distance covered = the rope's lenght (h1) :
(vi2)² = (vi1)² + 2gh1
(19,44)² = 0 + 2(9,81)(h1)
h1 = (377,91)/19,62
h1 = 19,26 m
Time to reach a speed of 70 km/h
t1 = vi2/g
t1 = 19,44/9,81
t1 = 1,98 s
The remaining distance (after the bungee engages) :
h2 = 47 - 19,26 = 27,74 m
Deceleration :
a = (vi2)²/2h2
a = (377,91)/2(27,74)
a = 13,62 m/s²
Since his speed when he hit the water surface is equal to zero, then:
0 = vi2 - at
t2 = (19,44)/(13,62)
t2 = 1,42 s
total time = t1 + t2 = 1,98 + 1,42 = 3,4 s.
Is it correct?
h1 = (377,91)/19,62
h1 = 19,26 m
t1 = vi2/g
t1 = 19,44/9,81
t1 = 1,98 s
Deceleration :
a = (vi2)²/2h2
a = 13,62 m/s²
0 = vi2 - at
t2 = 1,42 s
Is it correct?
Assuming it is supposed to just be a kinematics problem, it's one plausible interpretation. As has been pointed out the question is poorly posed. Another could be using the equations of simple harmonic motion to find the time of the last portion (as @Steve4Physics points out) if you have studied that?
For future reference, algebraic manipulations are preferred until the last step, and the site has math formatting capabilities. Please see: LaTeX Guide.
Likes MatinSAR
Why do you think the max speed is when the bungee first becomes taut? Will the acceleration instantly change from g to zero?
Likes MatinSAR
Do we have an equation to invoke for rate of change of acceleration over the transition?
SHM.
haruspex said:
SHM.
While that may be consistent with the SHM interpretation ( which may be the intention ), that is not consistent with the model the OP chose to evaluate (the one you quote).
However, if we invoke SHM, then at the onset of the spring force ##o## the velocity of the jumper is then:
$$v(t) = v_o \cos ( \omega t ) $$
Which appears to be maximized at ##t = 0##, with ##v(0) = v_o ##. What am I missing?
See my Post #13!
Steve4Physics said:
See my Post #13!
About what though? @haruspex seems to be implying in #19 the velocity of the jumper increases after the spring begins to stretch beyond that of their initial freefall velocity to that point? Maybe I have the wrong equation of motion.
Steve4Physics said:
See my Post #13!
With which I disagree. See post #17.
Max velocity is when the net force ….
Likes erobz and Steve4Physics
Yeah, I have the wrong equation of motion. The velocity is maximized when the acceleration is ##0##. I saw some pictures on wiki, but I didn't digest if the equation I grabbed for ##x(t)## were applicable here. I solved the ODE now, I see the blunder. Shameful approach!
Aha. Max velocity occurs when the tension first equals the weight. Up until that point, the net force (and hence acceleration) is downwards. So the speed increases until that point.
So... based on the actual equation of motion, solving system as I was trying to before using position and velocity at the water sure doesn't seem like it's going to be analytical?
Given the challenges surrounding the "SHM solution", I suspect the intended solution is as the OP has shown in #15.
I did find an analytical solution to the SHM problem after all. It's significantly more work for about ##0.4 ~\rm{s}## increase on total time when compared to the "constant force" approach in #15. I guess it's not insignificant...but it's pretty close for this one.
FAQ: Motion in straight line in bungee jumping
What is the initial acceleration of a bungee jumper?
The initial acceleration of a bungee jumper is equal to the acceleration due to gravity, which is approximately 9.81 m/s². This is because, at the start of the jump, the only significant force acting on the jumper is gravity.
How does the motion of a bungee jumper change after the cord starts to stretch?
Once the bungee cord starts to stretch, it exerts an upward force on the jumper. This force increases as the cord stretches more, gradually decelerating the jumper until they momentarily come to a stop before being pulled back up. The motion then becomes oscillatory as the jumper bounces up and down until the energy dissipates.
What factors determine the maximum velocity of a bungee jumper?
The maximum velocity of a bungee jumper is determined by the height of the jump, the mass of the jumper, and the characteristics of the bungee cord, such as its length and elasticity. The maximum velocity typically occurs just before the cord starts to stretch significantly.
How is the motion of a bungee jumper modeled mathematically?
The motion of a bungee jumper can be modeled using the principles of classical mechanics. Initially, the motion is described by free-fall equations under gravity. Once the cord stretches, Hooke's Law (F = -kx) comes into play, where k is the spring constant of the cord and x is the extension. The overall motion can be described by a combination of these equations, often requiring numerical methods for precise solutions.
What safety considerations are important in bungee jumping related to motion in a straight line?
Key safety considerations include ensuring the bungee cord's length and elasticity are appropriate for the jump height and the jumper's weight, checking the integrity of the cord and harness, and considering the potential for oscillatory motion after the initial fall. Proper calculations must ensure that the jumper does not come into contact with the ground or other obstacles.
