Motion in Two or Three Dimension : Projectile motion
In summary, the conversation discusses a projectile launched at a 60° angle above the horizontal on level ground, with a change in velocity of -20 y^ m/s between launch and just before landing. The initial and final velocities are unknown, and the attempt at a solution involved considering the equations Vox + Vfx = 0 and Voy + Vfy = -20. However, there are flaws in the problem statement, as it is unclear and potentially incorrect.
physicos
46
A projectile is launched at a 60° angle above the horizontal on level ground. The change in its velocity between launch and just before landing is found to be Δv = vlanding _ vlaunch = -20 y^ m/s .
What is the initial velocity of the Projectile ?
What is its final velocity just before landing ?
m/s .
3.The attempt at a solution
I considered :
Vox - Vfx = 0 and Voy - Vfy = -20
knowing that V²fy - V²oy= -2g (Yf-Yo) But I couldn't go further
What is the value of Yf-Yo?
Yes , just saw it ! I edited the post !
I have no idea about Yf-Yo ,I couldn't guess it from the problem statement !
It is launched from, and lands on, the same level ground.
so V landing = 0 ?? Because we know that v = sqrt(Vo²-2g(Y-Yo))
No, you should check your algebra on that equation. But regardless, there are serious flaws in the problem statement. Did you word it correctly?
Related to Motion in Two or Three Dimension : Projectile motion
1. What is projectile motion?
Projectile motion is the motion of an object that is launched into the air at an angle and follows a curved path under the influence of gravity.
2. What factors affect projectile motion?
The factors that affect projectile motion are the initial velocity, launch angle, and the force of gravity.
3. How is projectile motion calculated?
The motion of a projectile can be calculated using the equations of motion, which take into account the initial velocity, launch angle, and time of flight.
4. What is the difference between horizontal and vertical motion in projectile motion?
Horizontal motion is the motion of the object in the x-axis, while vertical motion is the motion in the y-axis. In projectile motion, the horizontal motion is constant, while the vertical motion is affected by gravity.
5. Can you determine the maximum height and range of a projectile?
Yes, the maximum height and range of a projectile can be determined using the equations of motion and solving for the maximum height and range values.
21K
