Why Do We Double Time in Speed Camera Calculations?
In summary: That's the idea. But, be careful about how far the pulse travels (hint: the pulse makes a return trip).
Krashy
30
[/B]
Equations of motion:
v = u + at
s = 1/2 (u + v) t
s = ut + 1/2at^2
v^2 = u^2 + 2as
3. The Attempt at a Solution
Hello, on a i used the 2nd equation:
30m = 1/2 (3*10^8m/s+3*10^8m/s) t so -> t = 1*10^-7s
but to get the correct solution i need to take t*2 i think. I made a small sketch to this question, but i don't really know why i need to take it times 2, is it because of sending and receiving the signal?
I hope someone can explain this to me.b was a lot more confusion for me because of the two time values:
first i used s = v*t
s = 3*10^8m/s * 2.14 * 10^-7s so -> s = 64.2m
this is where i get lost, so now i used the 2nd equation again with the other time value:
64.2m = 1/2 (0m/s + final velocity) * 0.1s so -> v (final velocity) = 1284 m/s
so I am pretty sure that's waaay to high, but i think the first part is correct.
Thanks for every answer.
Exactly, the light pulse must travel to the car, be reflected and travel back again.
You need to think more clearly what happens in the ##0.1s## between pulses. What is different? Does anything move ##64.2m##?
Likes Krashy
thanks for your answer,
i think only the car moves further away in 0.10s but i don't have the velocity of the car, so i can't figure out how far it gets, can i? Or do i need to subtract the 0.1s from the given 2.14*10^-7s to make up for the delay of the 2nd pulse?
Finding the speed of the car is the point of the speed gun!
Fundamentally, what does firing a pulse of light at a car and measuring the time it takes to come back tell you? If you fired a pulse of light at the moon and it reflected and came back ##2.5s## later, what does that tell you about the moon?
Likes Krashy
it tells us the distance to the moon, doesn't it? That means we can use the time that the pulse travels and its known velocity to determine the distance to the car (64.2m). With the following pulse we can then determine the distance the car moved in the next 0.1s, so the total distance over the time both pulses took to reach it, is the cars velocity, is that correct?
Hint: what happens if the car is not moving?
Likes Krashy
All right now i think i got it. The distance it was away after 0.1s wasn´t 64.2m but 32.1m, i got confused because of the return trip.
So the change in distance in 0.1s is 32.1m - 30m = 2.1m and now we know the distance the car moved in 0.1s, so:
v = 2.1m/0.1s = 21m/s -> 75.6 km/h
is that correct?
Likes PeroK
Krashy,
If you multiply the speed of light by the time between pulse emission and registration, won't that give about twice the
final distance to the car? Thanks for posting this question!
Yeah that´s why you halve the time between pulse emission and registration, so you only get the distance from emission to the back of the car. So in this case for b you don't use 2.14*10^-7s but 1.07*10^-7s to get the right value.
Related to Why Do We Double Time in Speed Camera Calculations?
1. How do speed cameras work?
Speed cameras use sensors to detect the speed of a vehicle passing by. They then capture an image of the vehicle and its license plate. This information is used to determine if the vehicle was speeding and if a ticket should be issued.
2. What types of speed cameras are there?
There are several types of speed cameras, including radar-based cameras, laser-based cameras, and average speed cameras. Some cameras are fixed in a certain location, while others are mobile and can be moved to different areas.
3. Can speed cameras make mistakes?
Like any technology, speed cameras can make mistakes. Factors such as weather conditions, human error, and incorrect calibration can affect the accuracy of speed cameras. However, these cameras are regularly tested and maintained to minimize errors.
4. How are speed camera tickets issued?
If a speed camera captures an image of a vehicle breaking the speed limit, the information is sent to the relevant authorities. They will then review the evidence and decide whether to issue a ticket or not. The ticket is usually sent to the registered owner of the vehicle.
5. Do speed cameras actually reduce speeding?
Studies have shown that speed cameras can effectively reduce speeding and improve road safety. When drivers know that there are speed cameras in place, they are more likely to follow the speed limit, resulting in fewer accidents and injuries on the road.
