Motion Near Earth's Surface - grade 11 physics
In summary, the conversation discusses a physics problem where a person is carrying a 2.0kg cake box on a bus and needs to calculate the force exerted on the string holding the box. The solution involves using the equations F=ma and Fnet=Fg+FN to determine the force. The original answer of -14.6N is incorrect, and the correct answer is 24.6N due to the equal and opposite forces of the box and the string. The conversation also includes a discussion on another example problem involving an elevator and a girl falling into a pile of hay, which further explains the concept of equal and opposite forces.
sarmar
a) Cathy takes the bus home from work. In her hand she holds a 2.0kg cake box, tied together with a string. As she ascends the steps into the bus, the box accelerates upward at a rate of 2.5 m/s^2. What is the force exerted on the string?
F=ma
Fnet=Fg+FN
Fnet=Fg+FN
ma=Fg+FN
FN=ma-Fg
= (2.0)(2.5)-(2.0)(9.8)
= 5-19.6
=-14.6N
Therefore the force exerted on the string is 1.5x10N[upward]
-I am taking an independent physics course. I always do the question as best I can first, then I check this forum for verification, it helps so much. But for this question, it says that 24.6N is correct.
I followed the examples in my course book exactly so I don't know why it would be 24.6N.
I mean I understand how to get 24.6 but why would (2)(9.8)=19.6 turn negative if the box accelerates upward? Wouldn't it remain positive?
Or is 24.6 wrong? Confused.
Thanks in advance.
your not taking into account that the box and the string act in equal and opposite directions. When you go up on an elevator, doesn't it feel as if you are of a greater mass? This concept is the exact same as the box and string.
you can see that 19.6+5 = 24.6N
Thank you :) that does make sense.
It's just that my course book shows:
Fnet=Fg+FN
ma=Fg+FN
FN=ma-Fg
and so that's what I've been following.
Could you possibly explain it expressed in this way?
In the original, you just did the math incorrectly: It's the F(up) - mg = ma. So F = ma + mg. In your coursebook, could you state the problem that it's listed for?
There is no question or example in my book that shows
F(up) - mg = ma
F = ma + mg
Only examples using
FN=ma-Fg
are used.
For example:
Carla carries a spring balance with her on a fishing trip. She catches a fish, weighs it on the scale and gets a reading of 5.0N
In the elevator Carla notices the scale no longer reads 55.0N. The elevator is accelerating upward at a rate of2.0m/s^2, what reading does she see?
Answer:
FN=ma-Fg
=(5.61kg)(2.0m/s) - (-55.0N)
=11.22N+55.0N
=66.2N
This following example is why I originally thought the answer -14.6N, was 14.6N[upward]:
A 50.0kg girl falls 3.0m from a loft into a pile of hay. She is brought to rest by the hay in a distance of 1.0m. What is the average force exerted by the hay?
Answer:
Is broken up into first part of the fall and second part:
at the very end of the solution for this example it shows:
=ma-mg
=(50)(-29.4m/s) - (50)(9.8m/s)
=-1960N
Therefore the hay exerts a force of 2.0x10^3[upward] on the girl.
FAQ: Motion Near Earth's Surface - grade 11 physics
1. What is the difference between speed and velocity?
Speed is the rate at which an object is moving, while velocity is the rate at which an object is moving in a specific direction. Speed is a scalar quantity, while velocity is a vector quantity.
2. How is acceleration calculated?
Acceleration is calculated by dividing the change in velocity by the change in time. The formula is: acceleration = (final velocity - initial velocity) / time
3. What is the formula for calculating distance traveled?
The formula for calculating distance traveled is: distance = speed x time. This formula assumes that the speed is constant, and the object is moving in a straight line.
4. How does air resistance affect motion near Earth's surface?
Air resistance, also known as drag, can slow down an object's motion near Earth's surface. This is because the air particles exert a force on the object, opposing its motion.
5. Can an object have a constant speed but changing velocity?
Yes, an object can have a constant speed but changing velocity if it is changing direction. This is because velocity takes into account both the speed and direction of an object's motion. So, even if the object is moving at the same speed, a change in direction will result in a change in velocity.
