PumpkinCougar95
In a homogeneous, non-magnetic, highly insulating and viscous medium, a moving particle experiences a viscous drag given by the law f→=−bv→. Here b is a positive constant. A particle having charge q is projected with an unknown velocity from a point in the medium. It almost stops after traveling a distance of 10m10m in a straight line. Now a uniform magnetic field is established in the region and the same particle is again launched with the same velocity perpendicular to the magnetic field.
In the presence of above magnetic field, if the particle almost stops at a point 6m from the point of projection, then find the magnitude of magnetic field in terms of q and b.
[/B]
https://drive.google.com/file/d/0B2jHGkWhC0E2bElTelB3aVNZTXc/view?usp=sharing
https://drive.google.com/file/d/0B2jHGkWhC0E2ajljRjJqempLeXM/view?usp=sharing
https://drive.google.com/file/d/0B2jHGkWhC0E2T2ZjRzE4eGh3eFk/view?usp=sharing
w is the angular velocity about the origin^. X,Y are the displacement of the particle in X and Y direction when v=0.
The trajectory is a spiral. I was able to find the velocity v as a function of time .
I was able to find the trajectory of the particle in polar coordinates( taking the centre of the spiral as the origin), and the distance of the starting position from the origin. But i can't find the magnetic field. In fact, I think that the magnetic field may not be constant. Am I correct? If not then how to solve this questions?
https://drive.google.com/file/d/0B2jHGkWhC0E2bElTelB3aVNZTXc/view?usp=sharing https://drive.google.com/file/d/0B2jHGkWhC0E2ajljRjJqempLeXM/view?usp=sharing https://drive.google.com/file/d/0B2jHGkWhC0E2T2ZjRzE4eGh3eFk/view?usp=sharing
