Motion of Falling Body w/ Varying Drag: Farah's Q on Yahoo Answers
In summary, using Newton's second law of motion and the given information, we find that Luke's velocity and displacement can be described by v(t)=250(1-e^(-t/25)) and x(t)=250(-25e^(-t/25)-t+425). His limiting velocity is approximately 250 m/s and if the Millennium Falcon takes 200 seconds to turn around for a second rescue attempt, the rescue would be made at approximately 56247.9033585756 m from the ground.
MarkFL
MHB
13,288
Here is the question:
Luke Skywalker (m=100kg) fell from rest off the antenna below the cloud city of Bespin (height=100000 m).
Assume that he missed the Millennium Falcon waiting below and continued to plummet. Suppose the gravitational acceleration of Bespin is 10 m/s^2, and the force of drag provides resistance proportional to the magnitude of his velocity, with a drag coefficient of k=4. This question is also from my differential class thank you in advance.
Additional Details:
a) Find Luke's velocity and displacement.
b) Find Luke's limiting velocity.
c) Suppose it would take 200 seconds for the millennium falcon to shake of the pursuing TIE fighters and turn around for a second rescue attempt. How far from the ground would the rescue be made?
I have posted a link there to this topic so the OP can see my work.
Mathematics news on Phys.org
Re: Farah's question at Yahoo! Answers ragarding motion of a falling body where drag varies as veloc
Hello Farah,
I would begin with Newton's second law of motion:
\(\displaystyle ma=F\)
Since acceleration $a$ is defined to be the time rate of change of velocity $v$, we may write:
\(\displaystyle m\frac{dv}{dt}=F\)
We have two forces acting on Luke...the force of gravity and drag, which we are told is proportional to his velocity, hence:
\(\displaystyle m\frac{dv}{dt}=mg-kv\)
We subtract the force due to drag since it opposes the motion. Treating $dv$ and $dt$ as differentials, we may separate variables to obtain:
\(\displaystyle \frac{dv}{mg-kv}=\frac{dt}{m}\)
Integrating we find:
\(\displaystyle \int\frac{1}{mg-kv}\,dv=\frac{1}{m}\int\,dt\)
\(\displaystyle \ln(mg-kv)=C-\frac{kt}{m}\)
Converting from logarithmic to exponential form, we find:
\(\displaystyle mg-kv=Ce^{-\frac{kt}{m}}\) where \(\displaystyle 0<C\)
Solving for $v$, we obtain:
\(\displaystyle v(t)=\frac{mg}{k}-Ce^{-\frac{kt}{m}}\)
Now, we are told Luke begins at rest, which means \(\displaystyle v(0)=0\), and so from this initial value, we may determine the parameter $C$:
\(\displaystyle v(0)=\frac{mg}{k}-C=0\,\therefore\,C=\frac{mg}{k}\)
And so the solution satisfying the IVP is:
\(\displaystyle v(t)=\frac{mg}{k}-\frac{mg}{k}e^{-\frac{kt}{m}}=\frac{mg}{k}\left(1-e^{-\frac{kt}{m}} \right)\)
With $k=4\,\dfrac{\text{kg}}{\text{s}},\,m=100\text{ kg},\,g=10\,\dfrac{\text{m}}{\text{s}^2}$, we then have:
\(\displaystyle v(t)=250\left(1-e^{-\frac{t}{25}} \right)\)
Next, we may determine Luke's position $x(t)$ above the ground by using the definition:
\(\displaystyle \frac{dx}{dt}\equiv v(t)\)
If we orient our vertical $x$-axis such that the origin is on the ground and the positive direction is up, or opposing velocity, we then have:
\(\displaystyle \frac{dx}{dt}=250\left(e^{-\frac{t}{25}}-1 \right)\)
Separating variables, we obtain:
\(\displaystyle dx=250\left(e^{-\frac{t}{25}}-1 \right)\,dt\)
and integrating:
\(\displaystyle \int\,dx=250\int e^{-\frac{t}{25}}-1\,dt\)
\(\displaystyle x(t)=250\left(-25e^{-\frac{t}{25}}-t \right)+C\)
Now using the fact that $x(0)=100000$, we may use this to determine the parameter $C$:
\(\displaystyle x(0)=250\left(-25 \right)+C=100000\,\therefore C=106250\)
\(\displaystyle x(t)=250\left(-25e^{-\frac{t}{25}}-t \right)+106250=250\left(-25e^{-\frac{t}{25}}-t+425 \right)\)
Now we may answer the questions:
\(\displaystyle x(t)=250\left(-25e^{-\frac{t}{25}}-t+425 \right)\)
\(\displaystyle \lim_{t\to\infty}v(t)=250\,\frac{\text{m}}{\text{s}}\)
\(\displaystyle x(200)\approx56247.9033585756\text{ m}\)
FAQ: Motion of Falling Body w/ Varying Drag: Farah's Q on Yahoo Answers
What factors affect the motion of a falling body with varying drag?
The motion of a falling body with varying drag is affected by several factors, including the mass of the object, the gravitational force, the air resistance or drag force, and the initial velocity of the object.
How does air resistance affect the motion of a falling body?
Air resistance, also known as drag force, is a force that opposes the motion of a falling body. As the object falls, air molecules collide with the object, creating a drag force that slows down its motion.
What is the equation for calculating the motion of a falling body with varying drag?
The equation for calculating the motion of a falling body with varying drag is known as the drag equation: Fd = 1/2 * rho * v^2 * Cd * A, where Fd is the drag force, rho is the density of air, v is the velocity of the object, Cd is the drag coefficient, and A is the cross-sectional area of the object.
How does the drag coefficient affect the motion of a falling body?
The drag coefficient is a measure of the shape and surface properties of an object. It affects the amount of drag force exerted on the falling body, with higher drag coefficients resulting in more drag force and slower motion.
Can the motion of a falling body with varying drag be predicted accurately?
Yes, the motion of a falling body with varying drag can be predicted accurately using mathematical equations and physical principles. However, it may be affected by other factors such as wind and turbulence, making it difficult to predict with absolute precision.
