songoku
- 2,322
- 331
Two particles A and B of masses m and 2m are attached to the ends of light inextensible string which passes over smooth fixed pulley. The particles are released from rest and when particle B has moved h meters, it hits the ground and does not rebound.
(i) Find the speed of the particles just before B hits the ground
(ii) Find the direction and magnitude of the impulse that the particle B exerting on the ground
(iii) In the subsequent motion, B will rest on the ground until it is jerked into motion again. Find the period of time when B is resting on the ground before it is first jerked into motion
(iv) Find the speed when B first leaves the ground
(v) After jerked into motion, B rises up and then drops to hit the ground again. Find the distance B travels between the first hit and the second hit on the ground
(vi) The motion continues with B hitting the ground and jerked into motion indefinitely. Find the total distance traveled by B from the instance that the particles are released from rest.
v2 = u2 + 2ad
v = u + at
d = u.t + 1/2 at2
ΣF = m.a
(i) acceleration of system = g/3
v2 = u2 + 2ad
[itex]= \sqrt {\frac{2gh}{3}} [/itex]
(ii) Impulse on B = m . Δv = [itex] m . (0 - \sqrt {\frac{2gh}{3}}) [/itex]
[itex] = m . \sqrt {\frac{2gh}{3}}[/itex]
So the impulse on ground is downwards
(iii) Period of time when B is resting = twice the period of time for A to travel (after B hits the ground) to max. height, so:
[itex]v = u - gt[/itex]
[itex] 0 = \sqrt {\frac{2gh}{3}} - gt [/itex]
[itex] t = \sqrt {\frac{2h}{3g}} [/itex]
(iv) Speed when B leaves the ground = speed when B almost hits the ground [itex]= \sqrt {\frac{2gh}{3}} [/itex]
(v) distance of B = twice the distance when it accelerates upwards + decelerate to stop (when A hits the ground)
Distance when B decelerates to stop:
v2 = u2 - 2gd
0 = 2gh/3 - 2gd
d = h/3
So total distance = 4h + 2(h/3) = 14h/3Are answer from (i) to (v) correct?For (vi), the answer is infinite?
Thanks
