MHB Motion Problem Using F=Ma and s=ut+1/2xt^2
  • Thread starter Thread starter jakan
    F=ma Motion
The discussion centers on solving a motion problem involving a package dropped from an aircraft. The package, weighing 10 kg, is released from a height of 200 m while the aircraft travels at a speed of 150 m/s. It experiences a downward acceleration of 4 m/s² and a horizontal acceleration of -3 m/s². To find the horizontal distance for release, the time of fall is calculated using the vertical motion equation, and then this time is used in the horizontal motion equation. The impact force is not directly needed for the problem, but the discussion acknowledges the original query about it.
jakan
Firstly, appologies if this is in the wrong place or wrote wrong, total noobie here.
Ive been given some examples of math questions based on aviation, unfortunately this one didn't come with the correct answer or any example working and it seems a little more tricky than the others so I am struggling with where to start and knowing if I am getting decent answers. (Its for an oral examination with a maths element, don't worry the scenaria and numbers I get will be completely unknown to me):
A aircraft is conducting a low-level training supply drop run with the intention of dropping a 10kg package on a target location. The aircraft is at a constant speed of 150ms^-1 at an altitute of 200m.
At package release, the package is subject to a constant acceleration in a downward vertical direction of 4ms^-2 and in the horizontal direction of -3ms^-2 (ie against direction of travel).
At what horizontal distance from target should the package be released and what will the impact force be?
Equations given are F=ma and s=ut+1/2xt^2
Any help or pointing in right direction will be appreciated, other examples used other motion equations I had no issue with.
Mathematics news on Phys.org
Your equation s=ut+1/2xt^2 does not seem to be correct it is usually written s=ut+1/2at^2 where a is the acceleration.
you find t by looking at the motion vertically and then s using the value of t you have found in the horizontal equation
You don't really need "F= ma" since you are not given or asked about the force. You are given the vertical and horizontal accelerations so you need s= ut+ (1/2)at^2. The package has a downward acceleration of 4 m/s^2 and must fall 200 m. u is the initial speed but there was no initial downward speed so u= 0. So for the vertical motion (1/2)(4)t^2= 2t^2= 200. Solve that for t. (Notice that the acceleration is not negative because I am taking "downward" to be positive.)
You are told that the horizontal acceleration is -3 m/s^2. The initial horizontal speed is 150 m/s so the horizontal distance is given by d= 150t- 3t^2. Use the t determined above to find the distance the package will move horizontally while falling.
Well, to be fair, the OP did ask about the impact force in the latter part of their sentence.
Ah, thanks.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
