mikejm
- 40
- 2
Let's say you have a simple structure with two equal masses connected by a massless rigid baton of length L. Like this:
Imagine this structure is totally free in space. It is not hinged in any way. Then forces act on each mass in 2D (x,y). If you have the x and y force vectors acting on each mass, and knowing the two masses are linked, can you calculate the net acceleration of each mass that results?
ie. If you have:
L = length connecting masses
Fm1X = x-axis force on mass 1
Fm1Y = y-axis force on mass 1
Fm2X = x-axis force on mass 2
Fm2Y = y-axis force on mass 2
And the initial (x,y) coordinates of the two masses and their initial velocities, can you calculate the accelerations and new velocities after a certain increment of time?
Numerical solution is fine. Would want to be able to solve such a problem at an audio sample rate recursively for 100 similar elements per sample or so. At each sample I'd recalculate the x and y forces acting on each mass, then need to determine their new velocities/accelerations for the next time increment.
Obviously this would be trivial for a mass that is not connected to another in this way. I'm not sure how to take into account that they must remain a fixed distance apart (ie. linked by the "baton").
Thanks.
ie. If you have:
Thanks.
