Motional EMF in the frame of a moving wire
In summary, the concept of motional emf is introduced in the reference frame of the wire to explain the observed induced current, while in the reference frame of the magnetic field, the Lorentz force can be used to explain this phenomenon without the need for motional emf. This is a result of the understanding of electromagnetic fields and forces in different frames of reference in the context of special relativity.
feynman1
435
29
When a magnetic field is moving (moving magnet) while a wire isn’t---in the reference frame of the wire, there’s no known magnetic force/effect on the wire before the introduction of motional emf and relativity. If viewed in the reference frame of the magnetic field instead where the wire is moving, there’s no need of introducing motional emf as Lorentz force can be used to explain. So may I confirm if the perspective in the reference frame of the wire is the reason cause for introducing motional emf?
Don’t forget to describe the electric field and electric force. If you are going to be changing reference frames you need both.
I am not sure what you mean here. Can you write this explanation?
When the wire is moving, there's a similar Hall effect driven by qvB to deflect charges that ultimately turns into an emf. So there's no need of invoking a changing magnetic flux that induces an emf. That a changing magnetic flux induces an emf is considered a new concept.
Thank you for clarifying the second part of my question. What about the first? You didn’t describe the E fields or forces in the wire frame.
There's one electromagnetic field, and that's it. You have to always work with the complete field, if you change from one frame of reference through the other, and you have to use the Lorentz transformation of spacetime-fourvectors as well as the electromagnetic field components, which are the components of a 2nd rank antisymmetric tensor in Minkowski spacetime.
In the reference frame, where the magnet is moving you have both electric and magnetic components. The electric field acts on the electrons in the wire even when they are still at rest and thus a current can start to flow and then of course you need the complete Lorentz force including electric and magnetic field components.
In the reference frame where the magnet is at rest and the wire is moving, you have a pure magnetostatic field and the Lorentz force acts with the magnetic field acts on the electrons within the wire.
This is precisely the problem Einstein started his famous paper on special relativity in 1905. With SR all the apparent problems were finally completely understood, and no asymmetries in the description of the situation in either the moving-magnet or magnet-at-rest frame and a wire (or wire loop) occur anymore, as Einstein promised in the introduction to this paper.
Likes Delta2 and Dale
In the frame of the wire, there’s no known electric field/force to explain an observed induced current if there were no concept like motional emf.
Why not? The magnet is moving. What does Faraday’s law say?
So I think there’s nothing but Faraday’s law that can explain the induced current in the frame of the wire, but I consider Faraday’s law to be new. In the frame of the magnetic field, the wire is moving so qvB alone can explain the induced current without invoking Faraday’s law.
Yes what you say is sth way after Faraday’s law. This thread is trying to understand the logic when Faraday’s law came into being. I think, in the frame of the magnetic field, qvB can explain the induced current; in the frame of the wire, nothing can explain the induced current before Faraday. Do you agree?
It doesn’t work that way. You have to start with a complete solution to all of Maxwell’s equations in one reference frame. Then you can transform it to another frame to get a complete solution to Maxwell’s equations in that frame.
You cannot take part of a solution and transform it to get anything meaningful. Faraday’s law is an essential part of Maxwell’s equations, you cannot pick and choose parts to leave out and expect to get something that can be meaningfully transformed.
Dale said:
It doesn’t work that way. You have to start with a complete solution to all of Maxwell’s equations in one reference frame. Then you can transform it to another frame to get a complete solution to Maxwell’s equations in that frame. You cannot take part of a solution and transform it to get anything meaningful. Faraday’s law is an essential part of Maxwell’s equations, you cannot pick and choose parts to leave out and expect to get something that can be meaningfully transformed.
I’ve been speaking under the context as if Maxwell’s eqs weren’t established yet. This thread is to ponder on the advent of Faraday’s law.
Likes Delta2
You should have mentioned that in the OP, but I don’t think that changes my response. Without Faraday’s law you cannot meaningfully transform the fields.
An alternative way of asking my question. The change in magnetic flux has 2 parts, 1 the change in B, the other the change in area. The latter can be explained by qvB. The former has to resort to a new law: Faraday.
This doesn’t make any sense to me. Flux is just a quantity. I am not sure how any part of it is explained by one formula or another. Formulas explain relationships between quantities, not the individual quantities themselves. I don’t see what it means in this context for flux to be explained by either Faraday’s law or the Lorentz force law.
Sure, Faraday's Law says (in Heaviside-Lorentz units)
$$\vec{\nabla} \times \vec{E}=-\frac{1}{c} \partial_t \vec{B}.$$
The complete integral law for moving surfaces ##S## and their boundary ##\partial S## uses Stokes's integral theorem and Gauss's Law for the magnetic field, ##\vec{\nabla} \cdot \vec{B}=0##, leading to
$$\frac{1}{c} \mathrm{d}_t \Phi_{\vec{B}} = -\int_{\partial S} \mathrm{d} \vec{x} \cdot \left (\vec{E}+\frac{\vec{v}}{c} \times \vec{B} \right),$$
where ##\vec{v}(t,\vec{x})## is the velocity of the line elements of the boundary ##\partial S##.
Faraday's law of induction (not to be confused with Maxwell-Faraday equation) explains the emf due to both parts of the change in magnetic flux. That is Faraday's law of induction includes the case where the magnetic flux is changing due to the change of area enclosed or due to the magnetic field changing. Look at this proof
https://en.wikipedia.org/wiki/Faraday's_law_of_induction#Proof
Be sure to click on [show] link to see the details.
What is Faraday's law of induction vs. Maxwell-Faraday equation? The fundamental form are the local Maxwell equations, and there's one Faraday's law, which reads
$$\frac{1}{c} \partial_t \vec{B}+\vec{\nabla} \times \vec{E}=0.$$
That's the Maxwell-Faraday equation in differential form. In its integral form the surface and the boundary of the surface are constant in time. In Faraday's law of induction the boundary of the surface (and the surface) can vary in time and the time derivative is in front of the surface integral, that is Faraday's law of induction is
$$EMF=\frac{d}{dt}\int_{S(t)}\mathbf{B}\cdot d\mathbf{S}$$
while the Maxwell-Faraday equation in integral form is
$$\int_{\partial S} \mathbf{E}\cdot d\mathbf{l}=\int_S\frac{\partial \mathbf{B}}{\partial t}\cdot d\mathbf{S}$$
They reduce to the same equation if the boundary of surface S does not depend on time, but they are not the same thing if the boundary of the surface S changes with time.
Likes Dale
This is correct (up to a sign) only if ##S## and thus ##\partial S## are not moving, but if they are moving from the "Reynolds transport theorem" for surface integrals you get from the local form of Faraday's Law together with Gauss's Law for the magnetic field in local form the correct equation
$$\mathcal{E}=\int_{\partial S} \mathrm{d} \vec{x} \cdot \left (\vec{E}+\frac{\vec{v}}{c} \times \vec{B} \right)=-\frac{1}{c} \mathrm{d}_t \Phi_{\vec{B}}.$$
For moving surfaces you have the full electromotive force, including the electric and the magnetic piece, as it must be.
Likes hutchphd and Dale
All of which leads me to prefer the differential expression
Likes vanhees71
Indeed. The great confusion is that in many textbooks the authors use Stokes's integral theorem, which leads to the (still correct!) equation
$$\int_{S} \mathrm{d}^2 \vec{f} \cdot (\vec{\nabla} \times \vec{E})=\int_{\partial S} \mathrm{d} \vec{x} \cdot \vec{E}=-\frac{1}{c} \int_{S} \mathrm{d}^2 \vec{f} \cdot \partial_t \vec{B}$$
and then without much explanation and a thick red caveat sign interchange the time derivative with the integral on the right-hand side. This is allowed if AND ONLY IF the surface ##S## and its boundary are at rest.
Otherwise you have to use the "transport theorem" for surface integrals. I don't know an online proof for it except in the German Wikipedia (it's the only example, where the German Wikipedia is more complete than the English I now of):
https://de.wikipedia.org/wiki/Transportsatz#Transportsatz_für_Flächenintegrale
In my notation it reads
$$\mathrm{d}_t \Phi_B=\mathrm{d}_t \int_S \mathrm{d}^2 \vec{f} \cdot \vec{B}=\int_S \mathrm{d}^2 \vec{f} \cdot (\partial_t \vec{B} + \vec{v} (\vec{\nabla} \cdot \vec{B})-\int_{\partial S} \mathrm{d} \vec{x} \cdot (\vec{v} \times \vec{B}).$$
Now using ##\vec{\nabla} \cdot \vec{B}=0## and the differential form of Faraday's Law you get
$$\mathrm{d}_t \Phi_B = -c \int_S \mathrm{d}^2 \vec{f} \cdot (\vec{\nabla} \times \vec{E}) --\int_{\partial S} \mathrm{d} \vec{x} \cdot (\vec{v} \times \vec{B}).$$
Once more using Stokes's theorem you get the equation quoted above
$$\mathrm{d}_t \Phi_B=-\int_{\partial S} \mathrm{d} \vec{x} \cdot (c \vec{E} + \vec{v} \times \vec{B}).$$
Likes Dale, weirdoguy and Delta2
I think when applying transport theorem, there's an error with the position of the dot product in $$\vec{v} (\vec{\nabla} \cdot \vec{B})$$. The dot should've been between v and nabla.
Good. What the OP was asking is that v*B term wasn't a new thing thanks to Faraday's law, but E*dx term was observed in experiment and invented in theory after Faraday's law. Would you agree?
No, the formula given is correct. For a proof, see
https://itp.uni-frankfurt.de/~hees/publ/mameth-l3.pdf
Sect. 3.16.2. Though it's in German, I guess the formula density should be high enough that it's understandable.
That's nice of you. In order to tell what I missed, I'd better check the English version. Any? For from what I see, simply take the derivative of B(x,t) w.r.t. time yields a 2nd term I proposed, in line with transport theorem in fluids.
But the above technicality I don't care at this point. I really care about post #23.
I don't have an English version yet. So here it is
Let the time-dependent surface be described by the parametrization
$$\vec{x}=\vec{\xi}(t,q_1,q_2).$$
The surface element is
$$\mathrm{d}^2 \vec{f} = \mathrm{d}^2 q \partial_{q_1} \xi \times \partial_{q_2} \xi.$$
For an arbitrary vector field ##\vec{W}=\vec{W}(t,\vec{x})##
$$\Phi_W(t)=\int_F \mathrm{d}^2 \vec{f} \cdot \vec{W}=\int_Q \mathrm{d}^2 q (\partial_{q_1}\vec{\xi} \times \partial_{q_2} \vec{\xi}) \cdot \vec{W}(t,\vec{\xi}).$$
Then
$$\dot{\Phi}_W=\int_Q \mathrm{d}^2 q [(\partial_{q_1} \dot{\vec{\xi}} \times \partial_{q_2} \vec{\xi} +\partial_{q_1}\vec{\xi} \times \partial_{q_2} \dot{\vec{\xi}})\cdot \vec{W} + (\partial_{q_1}\vec{\xi} \times \partial_{q_2} \vec{\xi}) \cdot (\partial_t \vec{W} + (\dot{\vec{\xi}} \cdot \nabla)\vec{W}))].$$
Now we interpret ##\vec{v}=\dot{\vec{\xi}}## as a function of ##\vec{x}##. Then we have
$$\partial_{q_j} \dot{\vec{\xi}} = (\partial_{q_j} \vec{\xi} \cdot \vec{\nabla}) \vec{v}.$$
Plugging this in above after some longer calculation in the Ricci calculus (see my manuscript, for this part you really don't understand the German text), gives
$$\mathrm{d}^2 q \vec{W} \cdot (\partial_{q_1} \dot{\vec{\xi}} \times \partial_{q_2} \vec{\xi} +\partial_{q_1}\vec{\xi} \times \partial_{q_2} \dot{\vec{\xi}}) = \mathrm{d}^2 \vec{f} \cdot [\vec{W} (\vec{\nabla} \cdot \vec{v}) - (\vec{W} \cdot \vec{\nabla}) \vec{v}).$$
So finally we have [EDIT: corrected in view of #28]
$$\dot{\Phi}_W=\int_F \mathrm{d}^2 \vec{f} \cdot [\partial_t \vec{W} + (\vec{v} \cdot \vec{\nabla}) \vec{W} + \vec{W} \vec{\nabla} \cdot \vec{v} - (\vec{W} \cdot \vec{\nabla}) \vec{v})].$$
We can simplify this a bit by using
$$\vec{\nabla} \times (\vec{W} \times \vec{v}) = (\vec{v} \cdot \vec{\nabla} \vec{W} - \vec{v} (\vec{\nabla} \cdot \vec{W}) + \vec{W} (\vec{\nabla} \cdot \vec{v})-(\vec{W} \cdot \vec{\nabla})\vec{v},$$
which is also shown most clearly with a longer calculation in the Ricci calculus. Thus you can write [EDIT: Corrected in view of #28]
$$\dot{\Phi}_W=\int_F \mathrm{d}^2 \vec{f} \cdot [\partial_t \vec{W} + \vec{v} (\vec{\nabla} \cdot \vec{W}) + \vec{\nabla} \times (\vec{W} \times \vec{v})].$$
Finally we apply Stokes's theorem to the curl term:
$$\dot{\Phi}_W=\int_F \mathrm{d}^2 \vec{f} \cdot [\partial_t \vec{W}+\vec{v}(\vec{\nabla} \cdot \vec{W})] + \int_{\partial F} \mathrm{d} \vec{x} \cdot (\vec{W} \times \vec{v}).$$
Setting ##\vec{W}=\vec{B}## and using
$$\vec{\nabla} \cdot \vec{B}=0, \quad \partial_t \vec{B}=-c \vec{\nabla} \times \vec{E}$$
leads to the general Faraday Law in integral form
$$\frac{1}{c} \dot{\Phi}_B=-\int_{\partial F} \mathrm{d} \vec{x} \left (\vec{E}+\frac{\vec{v}}{c} \times \vec{B} \right)=-\mathcal{E},$$
where ##\mathcal{E}## is the complete electromotive force including both contributions from the electric and magnetic field.
Likes weirdoguy, Delta2, Dale and 1 other person
So nice of you translating all this!
Thanks a ton @vanhees71 for the nice derivation. Just to correct some small typos, I believe in the formula you write after "So finally we have" the third term should be $$\vec{W}(\vec{\nabla}\cdot\vec{v})$$. And also about 5 lines down after "Thus you can write" again the third term should be $$\vec{\nabla}\times(\vec{W}\times\vec{v})$$
Thanks! I've corrected the typos.
Likes Delta2
FAQ: Motional EMF in the frame of a moving wire
What is motional EMF in the frame of a moving wire?
Motional EMF, or electromotive force, refers to the voltage induced in a wire that is moving through a magnetic field. This phenomenon is described by Faraday's law of induction, which states that a changing magnetic field will induce an electric field in a conductor.
How is motional EMF calculated?
The magnitude of the motional EMF can be calculated using the equation E = vBL, where E is the EMF, v is the velocity of the wire, B is the magnetic field strength, and L is the length of the wire in the direction of motion. This equation assumes that the wire is moving perpendicular to the magnetic field.
What is the direction of the induced current in a moving wire?
The direction of the induced current in a moving wire can be determined using the right-hand rule. If the thumb of the right hand points in the direction of the wire's motion, and the fingers point in the direction of the magnetic field, then the palm will indicate the direction of the induced current.
How does motional EMF affect the resistance of a wire?
Motional EMF does not directly affect the resistance of a wire. However, the induced current can cause a change in the wire's temperature, which can in turn affect its resistance. This is known as Joule heating.
What are some real-life applications of motional EMF?
Motional EMF is used in many devices, such as generators, transformers, and electric motors. It is also the principle behind induction cooktops and magnetic levitation trains. Additionally, motional EMF is used in scientific experiments to measure the strength of magnetic fields.
