Motivation for electromagnetic field tensor
In summary, there is no deep reason for introducing the electromagnetic field tensor other than the fact that Maxwell's equations can be written in a very succinct form in terms of it. A kinetic term for A would not be gauge invariant, so without it, the equations of motion cannot be written.
Bobhawke
144
Is there any deep reason for introducing the electromagnetic field tensor other than the fact that Maxwell's equations can be written in a very succinct form in terms of it? Would it be possible to write down a lagrangian involving a normal kinetic term for [tex] A^{\mu} [/tex] that reproduces the physics of electromagnetism correctly?
No, because a kinetic term for A would not be gauge invariant.
I know of two ways to get Maxwell's theory of electromagnetism from asking for the "simplest" theory of some class of theories. One to to ask for the simplest possible gauge theory --- then you would choose the simplest compact Lie group U(1) and minimal coupling; the other is to ask for the simplest Lorentz covariant field theory that couples to a 4-current linearly.
The need for F can be boiled down to this: E and B are observed to mix under Lorentz transforms, thus we can hypothesize that they are elements of a tensor. It cannot be the case that they are a 4-vector, because there are not enough degrees of freedom to express E and B. Thus we can go for the next simplest thing, which is a 2-form (antisymmetric 2-tensor); this happens to have exactly the right number of degrees of freedom.
Equations of motion can be written in terms of [tex]F[/tex] alone:
[tex] \frac{dp^{\mu}}{ds} = q F^{\mu\nu}u_{\nu} [/tex].
But anyway [tex] F_{\mu\nu} \equiv \partial_{\mu}A_{\nu}-\partial_{\nu}A_{\mu} [/tex] so [tex] A [/tex] is fundamental.
You can do this like in the following way, to obtain the Lagrangian density
of the massless or massive [tex]A^\mu[/tex] vector field:
[tex]
L ~~=~~\left\{\begin{array}{l}
~~+\Big(~~~\frac{1}{2}{\dot A_0}^2 ~-~ \frac{1}{2}\nabla A_0\cdot\nabla A_0 ~-~ \frac{1}{2}~m^2 A_0^2 ~\Big)\\ \\
~~-\Big(~~~\frac{1}{2}{\dot A_x}^2 ~-~ \frac{1}{2}\nabla A_x\cdot\nabla A_x ~-~ \frac{1}{2}~m^2 A_x^2 ~\Big)\\ \\
~~-\Big(~~~\frac{1}{2}{\dot A_y}^2 ~-~ \frac{1}{2}\nabla A_y\cdot\nabla A_y ~-~ \frac{1}{2}~m^2 A_y^2 ~\Big)\\ \\
~~-\Big(~~~\frac{1}{2}{\dot A_z}^2 ~-~ \frac{1}{2}\nabla A_z\cdot\nabla A_z ~-~ \frac{1}{2}~m^2 A_z^2 ~\Big)
\end{array}\right.
[/tex]
Which is the scalar Lagrangian for each vector component with the metric chosen so
that the whole still transforms like a scalar.
This is correct but it's only one half of the standard Lagrangian. The other half
term induces the same U(1) phase changes in a charged field and is therefor
indistinguishable from the Lagrangian above.
See section 22.9 of my book in progress:
http://physics-quest.org/Book_Chapter_Lagrangian.pdf
The same holds for the non-Abelian Lagrangian:
"The simplest derivation of the non Abelian field tensor and Lagrangian density"
http://www.physics-quest.org/Non_Abelian_Lagrangian.pdf
For a step by step treatment of the derivation of the Lorentz force from the U(1)
symmetry of the Klein Gordon equation using Wilson loops see:
http://www.physics-quest.org/Book_Lorentz_force_from_Klein_Gordon.pdfRegards, Hans.
Cool, thanks for the replies guys
Is there any reason why we couldn't get EM in terms of either
1) A rank 2 field strength tensor [tex] F_{\mu \nu} [/tex] with no symmetry/anti-symmetry requirements, and then choose a gauge to get rid of all the redundant dofs
or
2) A field tensor of rank>2 [tex] A_{\mu\nu\rho...} [/tex] with again the redundant dofs eliminated by fixing the gauge
For 2), I am reading something by t'hooft that says such a tensor field could not be introduced for 2 reasons: the energy density has to be bounded from below, and the theory has to be renormalisable ie all interactions have to have sufficiently low dimensions that their couplings have mass dimension greater or equal to zero. But I can't figure out why such a tensor would cause the energy density to be unbounded from below or why it would cause the theory to be unrenormalisable
If you choose to use a gauge theory, then your physical variable is a connection on some G-bundle over spacetime. The F-tensor is the curvature of this connection, and so will be antisymmetric by decree of mathematics --- nothing physical there. It so happens that for EM, if we choose a U(1) bundle, then F has 6 dofs and exactly express the electric and magnetic fields that we see. You can do a bit of group theory to figure out all the possible combinations of the connection (in coordinates, A_mu), which would not depend on the choice of basis, i.e. be gauge invariant. Then you find that F^2 is the only non-trivial possibility.
or
The simplest derivation possible of the Lorentz force:
Start with.
[tex]p_c^\mu ~~=~~ p^\mu+eA^\mu ~~=~~ -\partial^\mu\,\phi [/tex]
Where p is the inertial momentum depending only on the velocity
and [itex]\phi[/itex] is the phase of the field. The combination of p and eA can
not have any curl since [itex]\phi[/itex] is a scalar. So any curl in eA must
be compensated by an opposite curl in p.
[tex]-(\partial^\mu p^\nu-\partial^\nu p^\mu) ~~=~~ e(\partial^\mu A^\nu-\partial^\nu A^\mu) [/tex]
One obtains the Lorentz force by using [itex]U_\nu=\partial x_\nu/\partial \tau[/itex] to turn all
the spatial derivatives into time derivatives.
[tex] -\frac{\partial p^\nu}{\partial x_\mu}\,\frac{\partial x_\nu}{\partial \tau} ~~+~~\frac{\partial p^\mu}{\partial x_\nu}\,\frac{\partial x_\nu}{\partial \tau}~~=~~ eF^{\mu\nu}\,U_\nu [/tex]
The first term cancels, it represents the derivatives of the
invariant mass [itex]p_\nu p^\nu[/itex], so we obtain.
[tex] \frac{\partial p^\mu}{\partial \tau}~~=~~ eF^{\mu\nu}\,U_\nu [/tex]Regards, Hans
Related to Motivation for electromagnetic field tensor
1. What is the electromagnetic field tensor?
The electromagnetic field tensor, also known as the electromagnetic tensor or electromagnetic field strength tensor, is a mathematical construct that describes the electromagnetic field in spacetime. It combines the electric and magnetic fields into a single mathematical object.
2. What is the significance of the electromagnetic field tensor?
The electromagnetic field tensor is significant because it allows us to describe the behavior of electromagnetic fields in a relativistic framework. It also helps us understand the relationship between electric and magnetic fields, and how they are affected by the motion of charged particles.
3. How is the electromagnetic field tensor calculated?
The electromagnetic field tensor is calculated using the four-vector potential, which is a mathematical representation of the electromagnetic field. It is derived from Maxwell's equations, which describe the behavior of electric and magnetic fields.
4. What are some applications of the electromagnetic field tensor?
The electromagnetic field tensor has various applications in the fields of physics and engineering. It is used in the study of electromagnetism, particle physics, and Einstein's theory of general relativity. It is also essential in the development of technologies such as electromagnets, motors, and generators.
5. Are there any alternative theories to the electromagnetic field tensor?
There are some alternative theories that attempt to describe the electromagnetic field, such as the Wheeler-Feynman theory and the Stochastic Electrodynamics theory. However, the electromagnetic field tensor is the most widely accepted and successful theory for describing the behavior of electromagnetic fields.
