Joseph M. Zias
- 76
- 28
- TL;DR Summary
- using a solenoid wound armature may in the limit not be a good design.
There are many examples of a 2 pole motor/generator having an armature wound in solenoid fashion, albeit with a steel core. In the limit as the solenoid becomes more perfectly made, long and tightly wound, it would seem not be a good design. An ideal solenoid has zero magnetic field outside and I believe very little field at the ends (correct me if I am wrong). The magnetic field is intense within the core. It would seem that the very good solenoid coil would have difficulty being turned by the permanent magnet of the motor if the field is closely confined. It may work as a generator coil but the current would seem to be a pulse.
What are your thoughts? What shape would make for a better coil?
